Hi
i use premiere cc 2015 (more stable for me) & 2018
i would like to generate old tv noise or off line old brocasting tv like
https://www.youtube.com/watch?v=dnPB0WRUUdE
or
https://www.youtube.com/watch?v=V-nbvAnq65I
there are lots of effect i would love it ,but can't find right now
can i generate with Premiere cc or sony vegas 14?
or do i need a footage?
thanks
happy new year
Results 1 to 9 of 9
Easies/fastest would be to use a plugin. Commonly used plugins for premiere or after effects are bad tv, digieffects damage
https://aescripts.com/bad-tv/
https://www.digieffects.com/products/damage
There are internal methods in AE, tutorials how to emulate what those plugins do , but they take longer
There should be some avisynth scripts that emulate some things, and ffdshow had some effects you can apply, or aviutl I think has some "bad tv" effects as welll -
A cool "bad tv" shader for html three.js . It's as good as some paid plugins
Check out the example (click on it for randomize) , and click on the open controls box in the top right corner. Some nice controls .
http://felixturner.github.io/bad-tv-shader/example/
You can download the project, replace the video with your source video or modify the html file (the "video.src" line in the html file), and run it in your browser, screencap the effect
https://github.com/felixturner/bad-tv-shader
For the TV on/off effect, aviutl has a preset , but it's only mediocre IMO . Worth having a look at since its free too
White line wipe effect in Vegas?
By HeyItsDaniel in forum Newbie / General discussionsReplies: 5Last Post: 16th Aug 2017, 12:03 -
EMI/RFI Line Noise Filtering
By vhelp in forum Capturing and VCRReplies: 11Last Post: 1st Oct 2016, 15:34 -
VHS constant horizontal line noise
By kodec in forum RestorationReplies: 3Last Post: 19th Dec 2014, 16:23 -
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 15:03 -
Can a USB powered DAC filter out power supply noise from the USB line?
By MarcMiller in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2014, 04:37
