I have a movie that's default audio track is Spanish, and I need the English one (obviously). How can i remove the Spanish track using VirtualDubMod? I tried but didn't quite know what I was doing. If you could guide me step by step from when I open the program, I would greatly appreciate the help as this issue is really bugging me when I try to play it on my roku through dlna and I can't switch the audio track.. I should also add that the file format is .VOB.
If you can live with an MKV file, drag/drop the VOB onto MkvToolnix-gui, deselect the audio tracks you don't want, and select Start Multiplexing. You'll be done in a few seconds.
Its currently 'multiplexing', since its a little over 5 gigs its gonna take a bit more than a few seconds. I'll let you know if it worked.
BATCH remove audio track from mkv
By MarquisdeOz in forum AudioReplies: 53Last Post: 30th Jul 2018, 09:48 -
How do i remove an audio track from an AVI file?
By alih786 in forum AudioReplies: 51Last Post: 29th Nov 2016, 07:31 -
Remove an audio track
By vidblue in forum AudioReplies: 5Last Post: 26th Jan 2016, 00:18 -
How to remove one audio channel from a single audio track?
By helloguys in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2013, 13:35 -
Need to remove ONE audio track
By OneHit in forum AudioReplies: 9Last Post: 2nd Jan 2013, 08:14
