I just bought a "Fetch TV" PVR (Australia) https://www.fetchtv.com.au/ and subscribed to a cheapie subscription pack, since I can't afford Foxtel any more (it's very expensive).
Anyway, this thing apparently only plays a limited selection of file types from USB and home media servers, mainly MKV files containing mpeg4&mp3 or mpeg2&mp3. No MP4/avc&aac. Not the greatest format/codec support, but there it is, and it is the only alternative in Australia which offers subscriptions to some UK channels (they have great crime/detective shows from time to time).
I have lots and lots of home movies and whatnot in mp4/avc&aac (most interlaced, 1080i and 576i, a fair number 576p). Many of the videos have various audio offsets.
Hence, what in your view is the prevailing latest and greatest method to convert the .mp4 files into mkv/avc&mp3 or mkv/mpeg2&mp3 without lip sync issues etc ?
My initial guess would be via ffmpeg using say -c:v copy and -c:a libmp3lame -ab 384k and -y output_file.mkv which avoids transcoding the video ?
The quickest way to is to try MKVToolNix to put you files in a MKV container and see if they play in your device - it doesn't re-encode so is quick but wouldn't change the audio to a preferred format so probably ffmpeg is the best bet.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Looks good (common mp3 bitrate limit is 320k, though). Why don't you test it? There are so many different devices with so many different requirements that testing yourself is pretty much the only thing you can do. (If simple remux like netmask56 works: even better)
Note: "mpeg4" can mean different things. mpeg-4 part 10 is H.264/AVC, mpeg-4 part 2 is the old DivX/XviD thing. -
I would go for quality not bitrate - -q:a 0 should work very nice for libmp3lame.
OK and thanks. Testing it is, then.
-q:a 0 does sound attractive, however I wonder in this case
https://trac.ffmpeg.org/wiki/Encode/MP3
... the incoming audios range around 224k to 384k ...-q:a 0 (NB this is VBR from 22 to 26 KB/s)
and
which I suppose means I'm limited to 320k for mp3 ?-b:a 320k (NB this is 32KB/s, or its max) -
Thank you. Yes you are right, the spec appendix does say that.
I'd ignored .TS as a container without critical thinking, because everywhere you look people are talking about converting to use .mp4 and .mkv containers and not .ts. I now wonder why.
I googled to find pros and cons of .MKV vs .TS and saw not a lot.
https://en.wikipedia.org/wiki/Comparison_of_video_container_formats which says
https://en.wikipedia.org/wiki/MPEG_transport_streamMPEG transport stream TS (.ts) MPEG Patent encumbered
As far as I can tell, there's not much else in the way of describing under what circumstances to use one over the other (apart from .ts is intended for broadcast and is apparently a standard for blu-ray).because of the tiny packet size, streams can be interleaved with less latency and greater error resilience compared to program streams and common containers such as AVI, MOV/MP4, and MKV, which generally wrap each frame into one packet.
So far I suppose:
MKV Pros
- can contain just about anything
- can probably use vanilla ffmpeg to move to .mkv container
MKV Cons
- I'd need to transcode audio to mp3 for my particular hardware use case (so, slower conversion)
TS Pros
- more error resiliance
- no audio transcode required
- can probably use vanilla ffmpeg to move to .ts container
TS Cons
- none apparent
Clarifications welcome.
Existing .mp4 AAC transcode to .mp4 AVC
By MelRay in forum Video ConversionReplies: 2Last Post: 14th Aug 2016, 16:11 -
Converting from MP4-AVC to AVI-MP4(xvid)
By GruntVidStar in forum Video ConversionReplies: 24Last Post: 23rd Apr 2014, 15:34 -
Can't open .mp4 AVC/AAC video in Virtualdub
By sum_guy in forum EditingReplies: 4Last Post: 27th Feb 2014, 17:04 -
How to change .flv (Video:AVC Audio:AAC) to .mp4 without converting
By massafera in forum Newbie / General discussionsReplies: 12Last Post: 27th Feb 2014, 14:27 -
Best method to remux an FLV (AVC/AAC) file
By KeyMs92 in forum Video ConversionReplies: 13Last Post: 7th Sep 2013, 00:09
