Hi.
I am having some difficulty in editing this particular Divx file in Avidemux.
Using media info, this file is analyzed as per below screenshot, probably a variant of MP4.
https://www.dropbox.com/s/kgtsrn318kb27x8/Media%20Info%20for%20File.PNG?dl=0
Problem is I have tried to use most output formats in Avidemux and all are resulting in visible loss / deterioration in the video quality. The output formats I have tried are :
AVI, MP4, MP4v2, and MKV.
I have even tried to convert the original file to another format (MPEG2) through WinAVI Video Converter and then edit in MPEG Video Wizard but still same loss in quality.
Any advice on what is the best way to edit this file?
Thanks and regards.
This is already a low resolution, low bitrate file. But saying that, you should be be able to convert it
to mp4 or mkv using AVC compression and have it look close to the original.
What is wrong with the results you get now?
What do you mean by editing? What are you trying to do? -
Hi.
Thank you for your reply. Sorry for late response.
I am trying to edit the file using Avidemux. Although I have selected same output format as the original format (like avi muxer for avi files) the resulting file is slightly grainy and different color shades.
Can you help me locate a good (paid or free) software which can edit without encoding thus saving the original file state?
Many thanks. -
Avidemux should already be able to do it AFAIK (I don't really use it). Probably have to set video and audio to "copy" or something like that.
Alternatives: VirtualDub (Press F1 for help and see "Processing"->"Smart rendering" and "Processing"->"Direct mode"), SolveigMM Video Splitter, VideoReDo ...
(I can't see your screenshot so I'm just gonna assume DivX in AVI container. In the future it is better to set "View"->"Text" in MediaInfo and simply copy&paste the text here than to post screenshots.)
Quality loss after video editing / lossless conversation
By DunnoNo in forum Newbie / General discussionsReplies: 11Last Post: 24th Jun 2016, 09:34 -
Avoiding Codec Hades
By SameSelf in forum Video ConversionReplies: 6Last Post: 25th Feb 2016, 07:59 -
Difficulty with format of a found file.
By M. le Belfrey in forum Video ConversionReplies: 5Last Post: 10th Nov 2015, 06:18 -
Editing when mpg is your only source, while avoiding rerendering
By Jon.G in forum EditingReplies: 12Last Post: 8th Dec 2013, 01:04 -
Having difficulty with aspect ratio settings on captured avi file
By x22 in forum Newbie / General discussionsReplies: 8Last Post: 10th Sep 2013, 16:41
