Hi. I have a problem , I don't know exactly which but here it is. I create a bluray disc with menu and everything with dvd fab, burn it to a rewritable blueray disc which I tested it and it was playing perfect and finally burned it to a verbatim disc.The Samsung consumer which read the rewritable disc can't read the verbatim .Note that all my bluray discs are verbatim.So where could be the problem? I haven't change anything on my settings.Does anybody know from where I should begin? Thank you in advance
It's BD-R but all the rest before are the same Verbatim BD-R (43804). The problem is that I haven't change anything neither on my settings or the type of disc or the burner (Dvd fab).The weird thing is that I played this verbatim disc in an older samsung bluray player and it's working.What can I say?
There is no obvious problem that I can see. Maybe you could try burning the Blu-ray folders or ISO from DVDFab using ImgBurn, at a lower speed than 6X, as already suggested.
I don't use DVDFab, so I don't know if there are any settings that you could change that might improve compatibility.Ignore list: hello_hello, tried, TechLord, Snoopy329
Bluray Mkv to normal bluray disc
By Igniz in forum Video ConversionReplies: 3Last Post: 10th May 2017, 23:15 -
Sony BDP S1500 bluray player does not play .MKV file or burned bluray DVD
By theguy22 in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2015, 18:10 -
Is capturing a non-copyrighted bluray off of a bluray player illegal
By ezcapper in forum Capturing and VCRReplies: 13Last Post: 30th Jun 2015, 23:59 -
Samsung bluray 3D player don't play Some AVCHD disc
By obadvw in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Sep 2014, 03:02 -
Did they ever make a bluray disc changer or a bluray/vhs combo?
By yoda313 in forum Off topicReplies: 4Last Post: 28th Mar 2013, 17:03
