I am looking to transfer video and audio from an old 90s camcorder's RCA ports out into my iMac. Any recommendations for what type of cable/adapter/converter I should purchase to make this transfer possible? Am I looking for RCA to USB/Firewire/Thunderbolt?
You need a capture device of some kind for analog tape cameras. The Elgato Video Capture and its software are OS X compatible.
The recordings made by DV cameras should be transferred to the computer, not captured from the camera's analog connections. If your Mac doesn't have a Firewire port, you could use and Apple Thunderbolt to Firewire Adapter and a firewire 400 to 800 adapter. iMovie and FinalCut Pro X are supposed to work for Firewire transfers.
https://www.amazon.com/Apple-Thunderbolt-to-Firewire-Adapter/dp/B00SQ2CJUS
https://www.amazon.com/elago-FireWire-Adapter-MacBook-computers/dp/B003L4P872Ignore list: hello_hello, tried, TechLord, Snoopy329
Sony TRV-340E replacement RCA cable 3.5mm
By pavion in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 21st Apr 2017, 12:58 -
Need RCA male to video mini (8.5mm) male composite video cable
By Novice20 in forum Newbie / General discussionsReplies: 9Last Post: 11th Oct 2016, 10:00 -
RCA Cable
By blinky88 in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2015, 11:59 -
Capturing cable TV: are sources equivalent (cable box vs M-card tuner)?
By Nickster in forum Capturing and VCRReplies: 5Last Post: 12th Oct 2014, 16:45 -
No audio on one SCART cable,another cable is fine?
By SkC1998 in forum Newbie / General discussionsReplies: 25Last Post: 15th Feb 2014, 11:58
