I have captured a kanopy.com video stream, and saved the subtitles in a text file.
The subtitle stream is labelled Type 'html' and Cause 'xhr'.
The first three entries are:
<a href='#' begin="5.706" end="8.289"><span class='ts'>00:05</span> (music)</a>
<a href='#' begin="13.037" end="14.961"><span class='ts'>00:13</span> - A Swiss scientist</a>
<a href='#' begin="14.961" end="17.128"><span class='ts'>00:14</span> had a marvelous statement,</a>
Can anyone tell me how to convert this format to srt? Thank you.
Hi.
I could save your text in a txt file. After that, I opened such file using Subtitle Edit . And save it into srt format.
When I opened these srt file I could see:
1
00:00:00,209 --> 00:00:29,446
<a href='#' begin="." end="8.289"><span class='ts'>00:0</span> (music)</a>
2
00:00:00,542 --> 00:00:01,543
<a href='#' begin="." end="14.961"><span class='ts'>00:</span> - A Swiss scientist</a>
3
00:00:00,584 --> 00:00:40,082
<a href='#' begin="." end="17.128"><span class='ts'>00:</span> had a marvelous statement,</a>
It's boring, but maybe does it works. The timing and the essencial text remains. Deleting what is not important.
Maybe you can find other easier / automatic way to do it too.
Best regards.
devil (johner) -
johner, thank you very much for helping. I also tried Subtitle Edit, but note that it gives times that are wrong as well as superfluous text (the first title should start at 5.706 sec and end at 8.289 sec, not 00:00:00,209 --> 00:00:29,446) - so it would need a lot of editing. I also tried https://gotranscript.com/subtitle-converter - which failed to convert the file. I'm hoping someone will know a better way than via Subtitle Edit.
Hi, dear all.
@ barmah
OK, try latest beta: here
It could be helpful to see a complete file...
Nikse555, the Subtitle Edit programmer, gave me the answer above for your problem concerning subtitle convertion.
Please, test it and see if the things could be solved better. If you have more issues, report back!
PS: if needed, can you provide some complete subtitles samples for carefully testing?
Best regards.
devil (johner)Last edited by devilcoelhodog; 30th Dec 2017 at 08:04.
Or it needs someone who knows regular expression very well. Or you can send these subtitles to Subtitle edit developer. And there are some things on Github, but it is related to different site, which is probably no problem.
Bernix -
The author of Subtitle Edit is amazing! He has altered his excellent program so the file (https://files.videohelp.com/u/191845/test.txt) is correctly converted by the beta version of Subtitle Edit (at https://github.com/SubtitleEdit/subtitleedit/releases/download/3.5.4/SubtitleEditBeta.zip). Just run the beta version of Subtitle Edit, File, Open. Problem solved.
Thanks also to devilcoelhodog and Bernix for your help, which is much appreciated.
Extract subtitles from .ts file & convert to .srt
By xynd in forum SubtitleReplies: 4Last Post: 10th Dec 2017, 17:19 -
how to convert srt sub to idx sub or sup subtitles easily
By qaisark787 in forum SubtitleReplies: 6Last Post: 25th Nov 2016, 11:29 -
How do I convert DVD or sub/idx to text srt subtitles?
By Baldrick in forum SubtitleReplies: 70Last Post: 28th Mar 2016, 20:37 -
Subtitle Edit Convert SSA Subtitles To SRT Issues!
By kairukun in forum SubtitleReplies: 3Last Post: 14th Oct 2014, 02:58 -
Convert srt or ass subtitles to xml
By D Archangel in forum SubtitleReplies: 6Last Post: 19th Jun 2014, 02:16
