I'm curious what the best choice is for keeping audio lossless when doing x264/x265 MKV. I've just be doing passthrough AC3 or whatever, and it's worked so far. Not sure if FLAC is widely supported by players or not these days, but I was eyeballing that.
Passthrough AC3 or any audio codec is better than converting to FLAC, you can't get better quality but size will be bigger. At least I think.
Bernix -
The best way to retain lossless in an MKV file is just to keep it as is. If you want to reduce the file size a little, convert to FLAC. The problem is that FLAC is not really supported on any home theater equipment, so whether you keep the audio in the original format or convert to FLAC will depend on how you're playing the files. My suggestion would be to try a test file where you keep the original lossless track and then have a second track that is lossless ---> AC3 5.1 640k. My guess is that it will be indistinguishable from lossless. You will also save lots of space.
Bernix is right. If your audio source is AC3, converting it to FLAC will be of no benefit. It will only make the audio bigger and give you a less compatible A/V file.
Handbrake Question (Mpeg2 to .264)
By awtm in forum Video ConversionReplies: 11Last Post: 30th Apr 2016, 14:30 -
Handbrake Question
By Do0m3d in forum Video ConversionReplies: 6Last Post: 11th Nov 2015, 09:11 -
Question regarding DRC in Handbrake...
By Drake1132 in forum Video ConversionReplies: 5Last Post: 23rd Jul 2014, 15:09 -
Updated DVDfab9 and Handbrake Question.
By prezzacc in forum Newbie / General discussionsReplies: 6Last Post: 14th Sep 2013, 09:30 -
Question on Handbrake aspect ratio
By Bluelude1 in forum Video ConversionReplies: 11Last Post: 8th Jan 2013, 13:27
