Hello,
I'm building an AVI file programmatically from a list of images (MJPG) and a sound track. Until now it's working well, but I'd like to delay the audio at some sync position.
I tried the dwStart field but apparently it's not supported by players. I also tried to pad the beginning of the audio stream with zeros, but it didn't work.
Any help is welcome.
Hi,
delay whole audio from start it isn't probelm i.e. Avidemux can do this easily, If you need delay or some operation in the middle of your avi, I think only way is to use some NLE (non linear editing) software. BTW for project you are doing is it best to use such software, so probably you are actually using one. At least from my point of view.
Bernix -
ffmpeg isn't good for delaying in AVI. The only "good" solution for delaying in AVI is to encode actual silence before the audio. AVI Mux GUI does this, ffmpeg and VirtualDub don't. So preprending 0s might work for PCM, otherwise you have to encode the silence into your audio format (mp3, AAC, etc.)
All this advice to use external apps is not going to help someone who is writing a program to fabricate the AVI file.
As sneaker points out, you need to insert silent audio frames in the proper encoding for your sound format.
How do i remove an audio track from an AVI file?
By alih786 in forum AudioReplies: 51Last Post: 29th Nov 2016, 07:31 -
Avi Demux to replace an audio track with a new one
By loninappleton in forum Video ConversionReplies: 11Last Post: 20th Nov 2015, 01:31 -
How to edit Avi Audio with dual audio on one track?
By AleRthDia in forum AudioReplies: 2Last Post: 10th Oct 2014, 23:34 -
Any tool suggestion for Video having audio track delay of 10 seconds.
By nitinsagar22 in forum Video ConversionReplies: 8Last Post: 5th Dec 2013, 01:29 -
Subtitle and Audio delay when converting AVI
By badechi07 in forum SubtitleReplies: 0Last Post: 29th Jan 2013, 22:08
