    Apr 2002
    Richmond, Va
    Ok I have read all the posts and all of the guides and have a pretty good idea how to make a dvd-r. But if I want to make an exact copy of a dvd that is under 4.7 GB, do I have to do any authoring at all? Can I just rip with smartripper and burn? Or is it a step I must include. Please help because those damn dvd-r's are expensive!!
  2. Just use smartripper, and don't change a thing in the video_ts folder.
    Then use Nero(at least 5.5.8.0) to burn to dvd-r.
    You could use ifoedit and use the GET VTS SECTORS function on the two copied ifo files just to be sure, but i doubt that this is required.
    Sis
    don't mind the specs below, aren't correct anymore, got a new computer yesterday!!!!!
    P4 2Ghz
    512 MB ram
    40GB+20GB HD 7200 rpm( dma enabled)
    Pioneer DVR A03
    Sony 16x DVD-rom
    Canon HI8mm Camcorder
    Email: sis3970@msn.com
    Mar 2001
    Israel
    No authoring is needed(provided you have DVD burner like Pioneer A03}
    Use Dvd option in Nero and then choose disk copy.Simple.
