I need to merge X small video files (*.avi) to one video file that will contain all of them as one big movie.
I want to do it without opening the video compression in order to make this quick. all the files are with same frame size and bit rate.
How to do it?
Is it possible at all ?
Results 1 to 10 of 10
VirtualDub FilterMode or VirtualDub, use direct stream copy for video and audio
Also have to be same codec (& probably level & profile) and same framerate (or have timestamps & support vfr), and same color subsampling.
Scott -
If you can do mkv just use mkvtoolnix and append each clip to the first one. @tensor if their different setting per clip you gonna have to recode with handbrake megui etc first then join.
if all else fails read the manual -
Or you can use container more suitable for such goal - MPEG TS can be good container - even various codecs can be efficiently combined in single file.
How can you merge video files in Vidcutter?
By Stears555 in forum Video ConversionReplies: 3Last Post: 13th Apr 2021, 13:59 -
(Help Needed with ffmpeg) how do i batch merge audio files to video files
By wander799 in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2016, 15:40 -
LVT *UPDATED* [Beta 1.20] - Merge & Trim AVCHD Video Files
By mikey32230 in forum EditingReplies: 56Last Post: 17th Sep 2015, 13:30 -
HD video in .mts format. How would i merge multiple files of this type?
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 2nd Mar 2015, 05:28 -
Free program to merge mp4 & wmv video files with chapters?
By kcwebbah in forum Video ConversionReplies: 8Last Post: 28th Feb 2013, 17:07
