Hi - i'm searching for a software or a script or anything that can convert videos automaticlly
i have found "ffmpeg" .it can download and encode in one time but i am looking for a something that can encode anything from a directory. i have a directory address in web and my videos are in it and i will add more i want to script do the encode aotumaticlly.when i put a new video on that adress the script must be able to find it and encode it with ffmpeg
thats all i want - and i know some people have it or like this
thank you
AnotherGUI can be used as a GUI for ffmpeg and it has a "watch folders" option that can be used to watch different folders with different encoder presets if you so choose. Well.... at least that's how it appears to work. I've not used the "watch folders" option myself.
To enable "watch folders" you need to download the appropriate SQLite zip file and copy the files within to the same folder as AnotherGUI. The SQLite zip files can be found here. http://www.stuudio.ee/AnotherGUI/
Edit: I thought I'd give "watch folders" a spin and it certainly seems to work as advertised, but it did take me a few minutes to work out if you want to add a conversion preset or a folder to a new "watch folder" preset, after opening the "watch folder" window you have to double click in the empty space under the preset or folders column to open the dialogue. That's wasn't obvious to me as it's just an empty space so I thought I'd mention it..Last edited by hello_hello; 28th Dec 2017 at 11:14.
I use Hybrid with it's 'monitorFolder' and '-autoadd addAndStart' options from time to time to do this. (both are 'hidden' options)
On Linux this could also be easily done using a incrond entry with a script that is fed with the file,...
(I used this a few years ago to automatically process content recorded by multiple cameras which uploaded a new file every now and then into a shared folder.)
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Can you automate VideoRedo
By cgott42 in forum EditingReplies: 5Last Post: 17th Dec 2024, 20:31 -
[Vegas] How to automate pitch?
By rocco123 in forum EditingReplies: 2Last Post: 9th Jul 2017, 20:33 -
Any way to automate a number off conversions?
By StumpedTechy in forum Newbie / General discussionsReplies: 1Last Post: 14th Jun 2015, 14:10 -
how do i automate a website
By RBCC in forum Video Streaming DownloadingReplies: 8Last Post: 8th Nov 2014, 17:03 -
How to automate fcp to xml conversion
By jeromedroz in forum MacReplies: 1Last Post: 18th Jun 2013, 12:11
