Hello everybody,
I have a Panasonic DMR-ES10 which I want to use as a pass through device. But I have I have a few questions about this. To start of, my cable connections are:
Camcorder == s-video == DMR-ES10 AV4 input == s-video == capture card == VirtualDub
VHS == Scart to composite (s-video not possible) == DMR-ES10 AV4 input == s-video == capture card == VirtualDub
The results are better already. Ok, here are my questions:
1. Are there any specific settings needed with the Panasonic? Or is everything going by default?
2. There's also a option to output with component cables, which I also have. Is that possible/better? And what setting do you need in VirtualDub for that?
Many thanks
Turn off the noise reduction filter. It will lead to ghosting. Check the input/output levels. I'm not sure what's best for PAL but with NTSC they should be set to lighter (input), darker (output). Incorrect settings may result in mild posterization. With noisy consumer tape source this won't be an issue but with very clean sources it may be visible in smooth gradients.
For low res sources like VHS and Hi8 you won't see much difference between s-video and component. For high res sources, like downscaled HD broadcast TV, you will get noticeably sharper colors. -
Thanks a lot. I have turned off the noise reduction. Could not find the color input/output levels, but the colors seem to be fine already.
Using a Panasonic DMR-ES10 (UK-version) in the Netherlands (pass through)
By GovertdeKat in forum Capturing and VCRReplies: 3Last Post: 13th Dec 2017, 11:50 -
Correct way to connect a Panasonic ES10/15 as a pass through line TBC
By jimj in forum Capturing and VCRReplies: 14Last Post: 23rd May 2016, 17:39 -
Panasonic dmr-e100h & panasonic dmr e700bd recorders - disc release problem
By nanirdjeff in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Apr 2015, 13:59 -
Panasonic DMR-ES10 PAL Passthrough
By SpeciesOfPig in forum DVD & Blu-ray RecordersReplies: 3Last Post: 16th Jan 2014, 20:10 -
Panasonic DMR-85H rip settings
By chash in forum Newbie / General discussionsReplies: 6Last Post: 13th Feb 2013, 06:55
