Hi all,
Trying to convert a PAL dvd to NTSC using this script.
The problem I'm having is that at every shot change there seems to be 1 or 2 blended frames of the 2 separate shots. Is there anyway to tweak this script that may fix the issue?Code:SetMemoryMax(512) LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\DGDecode.dll") setmtmode(6,8) mpeg2source("VTS_02_1.d2v") setmtmode(2) assumetff() QTGMC(preset = "slow", EdiThreads=4) super = MSuper(pel=2) backward_vec = MAnalyse(super, isb = true,overlap=4, blksize=16,search=3,searchparam=4) forward_vec = MAnalyse(super, isb = false,overlap=4, blksize=16,search=3,searchparam=4) backward_vec = super.MRecalculate(backward_vec, overlap=2, blksize=8,search=3,searchparam=4) forward_vec = super.MRecalculate(forward_vec, overlap=2, blksize=8,search=3,searchparam=4) MFlowFps(super, backward_vec, forward_vec, num=60000, den=1001, ml=100)#59.94p lanczosresize(720,480) separatefields().selectevery(4,0,3).weave() converttoyuy2(interlaced=true)
Hmmm after looking at it again it may just be a crappy source. I did a double rate deinterlace (QTGMC) on the original source and there seems to be some frame blending on shot changes. So that just translates over when I do my conversion.
Your source may be an NTSC to PAL conversion with blended fields. The blending can be mostly eliminated with SRestore().
Hmm after looking over this some more, it almost seems like a straight telecide() seems to restore the frames. This gives me progressive 25fps video, but then I still need to get it to NTSC somehow. I'm guessing a slow down to 23.976 is in order?
I've attached a sample. -
Yes, it's just an out-of-phase PAL cap. You just need to get it back into phase with Telecide or TFM. Assuming you're making a DVD, you could soft telecine from 25 fps to 29.97 fps. Ie, encode at 25 fps with a progressive 720x480 frame, then use DgPulldown to add 3:2:3:2:2 pulldown flags. That will keep the original running time so you don't have to change the audio.
Or, if it's a movie, you could easily slow it to 23.976fps with a simple AssumeFPS(23.976) at the end of the script and then slow the audio to match. That's what I always do for for film sources. If it was created at 25fps then, yes, I'd do as jagabo suggests.
Now do you understand why, when asking questions about how to treat a video source, you should always provide a sample without even being asked?Last edited by manono; 28th Dec 2017 at 00:36.
Thanks Jagabo, that seems to produce the best output.
Manono - that's my bad, I should know better and should have provided a sample off the bat, my apologies.
Anyway to restore all frames from NTSC>PAL animation
By nick1977 in forum RestorationReplies: 39Last Post: 23rd May 2017, 06:01 -
NTSC blended
By xuguang_he in forum RestorationReplies: 3Last Post: 16th Dec 2015, 12:46 -
Removing Blended frames, then putting unblended duplicates back in??
By killerteengohan in forum RestorationReplies: 17Last Post: 16th Oct 2015, 03:37 -
DVD Styler Creating Blended Frames
By Rugratskid in forum Authoring (DVD)Replies: 2Last Post: 12th Feb 2015, 19:26 -
AviSynth or other way to remove blended frames from telecine film transfer.
By 5stringsteve in forum Video ConversionReplies: 45Last Post: 11th Apr 2013, 21:29
