  1. Hello,
    I'm running into a problem converting MKV with E-AC-3 audio, as reported by MediaInfo.
    When I run popcorn, it reports that none of the audio tracks can be converted or the conversion has been disabled:
    Audio Track #1 of codec A_EAC3 is not of the codec type that can be converted by AudioConverter
    I can run the eac3to conversion on the console once I demux it (the audio filename extension is .mka if that matters), then remux it and play the MKV with std AC3 for example.
    My audio tools show eac3to.exe path correctly under Program Files (x86)
    So why can't Popcorn handle this automatically?
    Running Popcorn 1.88 (running from c:\, not program files)
    eac3to v3.34
    Win7 x64
    -MW
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Have you tried the menu item "Simple Audio Conversion" found under main Menu item File in Popcorn Audio Converter 1.88 ?
  3. Thanks,
    That was too easy, I noticed it converted to wav then to ac3, an extra step but nonetheless quick and simple.
    Is something wrong in the original approach I took though? Or the eac3to conversion integration still glitchy?
