Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Hello.
    I will be capturing some old video 8 videos I have and am wondering if it is possible to capture a tape multiple times and then combine them to create one higher quality version? For instance, I know you can combine multiple photos to make a higher quality photo, so could this not be done with video 8? Since video 8 is analog, everytime it is captured the video will be slightly different, the noise, ect. So I am assuming this can be done if the software exists to do it.
    Thanks for your time
  2. Yes, it's possible. There is an AviSynth median filter that's very good for this. With Video 8 the noise on the tape is much stronger than the random playback noise. But it's good for removing random dropout "comets". If you don't have a line TBC you can reduce the horizontal time base jitter. But a line TBC is better for that.
