Results 1 to 11 of 11
    Aug 2005
    Europe
    With an LG 24MT58DF-PZ TV-Monitor (http://www.lg.com/uk/monitors/lg-24MT58DF-PZ), I can have sound through HDMI only using HDMI2 input, but not HDMI1 input. When I connect an HDMI cable to HDMI1 input and try to change the volume, a "connect audio cable" message appears on the monitor. Otherwise the HDMI1 input seems to be working fine. Is anyone aware of this issue?
  2. The TV is probably set to take audio from a separate SPDIF input when using HDMI1. Go through the setup menus and change it to take audio from the HDMI input instead.
    Aug 2005
    Europe
    I can't find anything related in the setup menus other than choosing input and labeling it.
    Aug 2006
    How have you labeled the HDMI1 input? Also, I think there is a PC Mode button on the remote. Does pressing the PC Mode button change anything?
    Aug 2005
    Europe
    On the remote, I select Inputs, then choose HDMI1, then Input Label and PC from available choices. There is only a TV/PC button that switches from full screen TV to full screen PC.
    Aug 2006
    Try labeling the port using something other than "PC" from available choices and use the "PC Mode" button for full screen PC. Maybe when the HDMI1 port is labeled "PC" the TV/Monitor is expecting a DVI video connection with audio provided via the PC line-in port.
    Aug 2005
    Europe
    I am currently using HDMI2 and sound works fine, but I am wondering if there is something wrong with HDMI1. I am not sure if I will continue using HDMI for this purpose, as sound works either for TV (in picture in picture) or PC (in full screen), but not simultaneously.
    Aug 2006
    I don't know if anything could be wrong with HDMI1. I think my LG TV and for certain my mother's Samsung have a designated HDMI port to use for PC connectivity, but that was documented in the manual. HDMI works fine for video and audio using either TV with a PC. I haven't tried any of the other HDMI ports to see what happens.
    I don't believe audio from two sources could be provided simultaneously without a mixer, like Windows (or the sound card drivers) provides. The TV probably doesn't include a mixer function.
    Aug 2005
    Europe
    I was advised that the HDMI port sometimes get stuck in DVI mode. Problem seems solved after resetting the monitor to factory settings.
  10. Member Cornucopia's Avatar
    Maybe needs a firmware update...
    Aug 2005
    Europe
    LG support said that there is no new firmware available.
