i rip 51st state film with smart ripper, use dvd2avi then tmpgenc. I load source video file ok. then i try to load audio file by opening state_AC3 T01 2_0ch 224Kbps DELAY 0ms.ac3 or other audio, but i get the mouse hour glass appear and the program hangs, other times i get a message saying something like unsupported file type or audio error of some kind. I've tried other films like dinosaur and that worked fine, but after testing it again that also didn't want to load the audio file. What is happening? It's driving me mad trying to get this to work.
Download BeSweet and BeSweetGUI and make it a .wav or sumthin..
You could also let DVD2SVCD to it for your or so...- Twin - -
kfarrow, first of all, i'm guessing you didn't try to test the audio file on media player first?
anywayz, in dvd2avi under audio dropdown menu, goto channel format and choose "auto select", then under dolby digital choose "decode" and try again
the audio file should be in .wav that can be played in mplayer, this should also work in tmpgenc -
Thanks for the help but the file works fine in media player. The .wav format loaded ok but when i loaded finished mpeg in power dvd, there was no sound! Any other suggestions would be appreciated.
There does'nt seem to be a .wav file when i decode with dvd2avi. Just the .d2v file!
ok...under audio...
make sure you have
channel format -> auto select
dolby digital -> decode
mpeg audio -> demux
as for track, usually try track 1 first, if you get no .wav file, then try track 2...so on, until u can get a .wav file (you can use the preview f5 to make sure that the track u have selected can be extracted to .wav..just look in the audio info in the info box that pops up when u preview)
but make sure you play the .wav file in mplayer b4 u encode to make sure it's the language u want
Scrabble game won't load
By Psco2007 in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2010, 20:41 -
convertx todvd won't load
By xbill in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2010, 15:22 -
Windows XP won't load
By Tom Saurus in forum ComputerReplies: 21Last Post: 12th Jun 2010, 10:36 -
Application won't load for all users
By mattman1968 in forum ComputerReplies: 9Last Post: 9th Nov 2007, 10:22 -
Program won't load?
By darrenp76 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Sep 2007, 03:36
