Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. Example of translation: https://abema.tv/channels/special-pl...DgvrRo98Z6supj
    Playlist: https://vod-abematv.akamaized.net/sl...st.m3u8?kg=160
    Here the address is coded:
    #EXT-X-KEY:METHOD=AES-128,URI="abematv- license://B9UtUPnVzpzjcq7ky1DHKFh8An1hya6VMGHRLWjf5SRZ",IV=0 x99fd8ee5a35713fb098efce763a7b2d1
    Found such a network request:https://license.abema.io/abematv-hls...ttU4KhVR8NUFVf
    cid: "DgvrRo98Z6supj"
    k: "CZeTXDGfq1X3qVMoFceexD5"
    I tried to edit the playlist and save it with fmmpeg, but it did not work.
    Tell me, please, how to do it correctly?
    Aug 2018
    India
    Hi...i am also trying to download it the same way you used...but it seems that it is sending requests to the server and gets a key and that key is used to play the video for over 5-30 sec and then it changes again...
    Also ffmpeg gives error on license , even though if you seperate those link it will give error by saying ts file has no data...
    Hence , its not possible to download it using ffmpeg
  3. The value of "k" does not change for a long time.The segments from the playlist are individually downloaded.
