Dear all,
Presently I'm collecting all kinds of portable software and prepare them all so I can place them all at once easily after re-installing Windows. To make those portable applications accessible in the Windows Start Menu I'll make shortcuts and save them in: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
I'll prepare two packages with portable apps:
- The first package is meant for 64bit Windows and the software will be stored into the folders "Program Files Portable (x64)" and "Program Files Portable (x86)". Everything that runs only on 64bit Windows comes into the first folder. The rest comes into the second folder.
- The second package differs from the first one by containing only the folder "Program Files Portable (x86)"
In the case of VirtualDub FilterMOD it's not 100% clear for me what what is:
[Attachment 44122 - Click to enlarge]]
These are the files and folder of VirtualDub FilterMOD. For 32bit Windows I assume you can delete the folder "plugins64" and the files "vdub64.exe", "VeeDub64.exe"and "VeeDub64.vdi". I assume as well you can delete the folder "plugin32" and the files "vdub.exe", "VirtualDub.exe" and "VirtualDub.vdi".
But what about additional 32bit plugins? The majority of those plugins is written for 32bit Windows. Can I use them with FilterMOD 64x and store them in an additional map called "plugins"? (Which is the case by the original VirtualDub)
- 64-bit VirtualDub cannot use 32-bit plugins.
- If you delete plugins32, regular VirtualDub 32-bit does not function correctly.
- You cannot put plugins in different/random folders.Want my help? Ask here! (not via PM!)
Can't create a WebM with VirtualDub FilterMod
By Bruce Banner in forum EditingReplies: 28Last Post: 15th Dec 2017, 12:47 -
VirtualDub FilterMod updated capture mode
By shekh in forum Capturing and VCRReplies: 1Last Post: 3rd Dec 2017, 15:05 -
virtualdub filtermod 40463
By carversm in forum Software PlayingReplies: 8Last Post: 30th Oct 2017, 12:41 -
Which exe to use to run VirtualDub FilterMod?
By kingmustard123 in forum Video ConversionReplies: 4Last Post: 23rd Jul 2017, 13:27 -
Which filters recommended for VirtualDub(Filtermod)?
By PabstBlueRibbon in forum EditingReplies: 3Last Post: 22nd Jul 2017, 11:00
