Hey, new to the page hereAlso new to video. Have a GoPro Hero 5, and decided to shoot a time lapse driving. I set the GoPro at one picture per half a second, which was the fastest it would go. The drive was probably 20 minutes. In Powerdirector 16, I loaded the photos and set them to the shortest duration possible, each clip for .01 seconds.It looks somewhat smooth, but not completely. If I meet a car from the other direction, it is obvious that it is stillshots, really bad jerking on the oncoming traffic. I cant figure out how to fix this. I thought of shutter speed at first, but the GoPro doesnt offer shutter speed adjustment on timelapse. What am I doing wrong??
I don't see how this would ever work. Time lapse is usually used on slow moving subjects like clouds across the sky
or flower petals opening. What is you aim ? -
Just a fluid driving video that looks sped up. Theres many on youtube to check out. But most of those are smooth, so i'm not sure how they are getting rid of the jeking affect.
You need to add motion blur. That's best done by shooting at normal speed and blending many consecutive frames together. And there's not much point in going over 60 fps in your final video. 0.01 seconds per frame is 100 fps. You'll typically see only 60 of the 100 frames each second because your monitor's refresh rate is 60 Hz. And that will look more jerky than seeing 60 evenly spaced frames. And lastly, don't speed things up too much or you will get a big blurry or jerky mess.
Great, thanks. How do I blend it in Powerdirector? I searched around a bit but I dont see it as an option. So maybe .02 seconds per frame (which makes it look very jerky), but then blending after setting that? Thanks for the help, sorry if these are such stupid questions, I just really want to figure this stuff out.
I don't know anything about Powerdirector. Some editors have a blend option with the frame rate filter.
You want 60 fps (or 59.94 fps for TV) for the smoothest display. That's 0.01666... second per frame (or 0.01668333... for TV).
Another way to get motion blur is to set the exposure to as close to the frame rate as possible. So for 1/2 fps you want close to 1/2 second exposure to get as much motion blur as possible. You'll probably need an ND filter in broad daylight though. -
Great, I'll search through Powerdirector a bit and see what I can find in that area. Thanks for the help
Time Lapse slower
By sarahtro in forum EditingReplies: 2Last Post: 30th May 2016, 08:51 -
Time Lapse Video
By itech in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2016, 15:16 -
Tricky time lapse
By CommanderLake in forum EditingReplies: 12Last Post: 25th Jul 2015, 01:54 -
time lapse
By Viacon in forum Newbie / General discussionsReplies: 26Last Post: 17th Nov 2013, 20:57 -
Time Lapse on a Bicycle
By Bluelemmy in forum Newbie / General discussionsReplies: 30Last Post: 7th Jun 2013, 12:55
