Hi all,
Wondering if there are any solutions for command line batch authoring. Basically what I have is a folder full of .mpv and corresponding .ac3 files. I would like to author each into a DVD structure with 5 minute chapter marks and no menu.
Are there any options to do this quick and easy?
My current method uses tmpgenc dvd author however it's very tedious for things like this.
DVDStyler has a CLI mode.
[Attachment 44110 - Click to enlarge]
Make a DVDStyler project Template.dvds using the file Muxed.mkv with the menu pre-command:
[Attachment 44111 - Click to enlarge]
and the post-command for the title
[Attachment 44112 - Click to enlarge]
Then use a batch file like
I havn't tested it but hope you get the ideaCode:for %%g in (*.mpv) do ( ffmpeg -i %%g -i %%~ng.ac3 -c copy Muxed.mkv DVDStyler /s /i %%~ng.iso Template.dvds )
PS Change the default chapter length from 10 min to 5 min
[Attachment 44113 - Click to enlarge]Last edited by videobruger; 23rd Dec 2017 at 16:31. Reason: PS
tsMuxeR command line
By t00 in forum Blu-ray RippingReplies: 7Last Post: 19th Nov 2017, 12:20 -
windows batch: paste but don't execute command in Windows command prompt
By flashandpan007 in forum ProgrammingReplies: 17Last Post: 22nd Jun 2016, 23:12 -
Command Line Batch File
By agent3lephant in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2014, 11:24 -
PotPlayer: Command Line
By burningbush in forum Software PlayingReplies: 5Last Post: 7th Dec 2013, 17:54 -
How to Use x264 Command Line
By Anonymous344 in forum Newbie / General discussionsReplies: 37Last Post: 2nd Nov 2013, 08:49
