I've got a BD with two movies on one disc The menus are basic and non-java.
I'm looking to back up only one of the two movies but with intact menus.
Normally when you load the disc you get the studio splash screen followed by a menu page asking if you want movie 1 or 2.
This is its own m2ts, 00006, called by playlist 00001.mpls. This sends you to a new menu just for the movie you pick.
The menu that matches the movie I want to back up is 00081.m2ts called by 00005.mpls.
Is it wrong/weird/inadvisable to just delete 00001.mpls (the one that calls the main selection menu) and replacing it with a COPY of 00005.mpls, the one that calls the menu page for the movie I'm keeping? (Ditto the CLIPINF & backup files.)
It seems like a solid idea that a quick test shows to work, but I don't want to run into compatibility or broken navigation issues down the line because I missed something.
Results 1 to 1 of 1
PotPlayer Navigation Bar Conflict with madVR?
By Michael Linder in forum Software PlayingReplies: 7Last Post: 9th Jan 2017, 00:03 -
Encore timeline navigation issues...
By jrodefeld in forum Authoring (Blu-ray)Replies: 2Last Post: 23rd May 2016, 11:40 -
DVD Architect Next Button Navigation Problem
By SameSelf in forum Authoring (Blu-ray)Replies: 13Last Post: 7th Dec 2015, 11:36 -
Login navigation messed up ...
By Hoser Rob in forum FeedbackReplies: 7Last Post: 21st Mar 2013, 11:50 -
Slow navigation problem with an mkv file
By HisDudeness in forum Blu-ray RippingReplies: 3Last Post: 6th Mar 2013, 02:52
