I bought a LG 4K UP875 blu ray. And I want and need to see some Blue Ray Discs from Zone 2 (Europe) And somebody told me that there are codes to put in the machine who help me to see them. Can anybody tell me How????
Thank you. I'll appreciate you help.
Results 1 to 11 of 11
Emilio, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And welcome to our forums.
Hacks for removing/negating/bypassing region code restrictions are becoming fewer and farther between, particularly for Blu-ray.
Your best best bet is to rip the disc (temp region change of drive to accommodate disc only if absolutely necessary) and save copy (iso) with region coding removed, then burn if you want/need to.
Scott -
Please pardon me!!!! How can I change the title? I need to know codes for watch BD from Zone 2 in my LG 4K UP875 blu ray
I doubt that you can change the region code of your LG 4K UP875 blu ray player. A Google search didn't find any offerings for this model.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Please is there any manner to convert Sony BP-S6500 from zone A to zone B?
they do have zone free players here - http://www.codefreedvd.com/region-free-blu-ray-players.html
I suspect you are out of luck.
Most Blu Ray players won't allow this. It's usually the off-brand ones that don't care so much about the rules where is can be done (I have a Veon branded one that does), and not the major manufacturers who tend to follow the rules more closely. And of all the major manufacturers Sony are pretty much the most plcked down, presumably because of their studio interests. Your choices are basically:
- rip the disc on a computer as per the advice above
- import another (region 2) player from Europe and hope your TV can cope with the output (the old PAL vs NTSC regions etc)
- buy another, region-free, player as per the advice above; or
- give up.
JAWS 3D Blue Ray
By wulf109 in forum Blu-ray RippingReplies: 6Last Post: 24th Jun 2016, 09:43 -
TV NTSC / PAL issues in Europe with DVD and Blue Ray
By westminster in forum DVD & Blu-ray PlayersReplies: 10Last Post: 5th Oct 2015, 01:01 -
blue ray to avi
By carolinedawn in forum Video ConversionReplies: 3Last Post: 9th Apr 2015, 07:59 -
Blue Ray on MPC HC
By iNfRaIiI in forum Newbie / General discussionsReplies: 4Last Post: 27th Jul 2013, 13:53 -
Blue Ray and DVD on same disk
By TreeTops in forum MediaReplies: 6Last Post: 9th Apr 2013, 05:17
