I've been trying to clip individual episodes from a full mp4 file using Handbrake to clip the relevant episode and encode the file. I would like to use the H.265 video codec to encode the new file as it appears to offer a better video quality compared to a similar sized H.264 encoded file. However, when I watch the x265 file using VLC and I click on various sections sometimes it freezes. It may freeze for a full second or not at all depending on where I click in the navigation bar. This doesn't happen at all when using the x264 codec. Does anybody know why this would be and have a solution to remedy this so there's no freezing when using the x265 codec?
	I don't know your computer specs, but h265 is more demanding on processing time than h264. So when you click somewhere at the end of GOP, it has to read whole GOP from start to frame you want to skip. There are several methods in players. Best is to allowed only play from start of the GOP on Keyframe. It is fastest method for bit slower computers. But don't know how to apply this method in VLC. Some GOP can be about 10-20 seconds long, so when you clicked on end it has to encode about 8s (200 frames) or 18s (450 frames) And in some cases GOP can be even longer. And of course bigger resolution the time is longer.
 EDIT
 Here is how it is solved in Potplayer
 [Attachment 44070 - Click to enlarge]
 BernixLast edited by Bernix; 20th Dec 2017 at 11:46. Reason: Added picture how this is solved in potplayer
  Encoding to X265 10 Bit with HandbrakeBy cloudxkillah in forum Video ConversionReplies: 24Last Post: 31st Oct 2017, 15:37
  Is x265 ready for Primetime.. Migrating From x264 to x265..By RazorBurn in forum Video ConversionReplies: 83Last Post: 31st Jan 2016, 08:14
  Simple multi video format test - x264, x265 and webmBy ricardouk in forum Video ConversionReplies: 0Last Post: 1st Oct 2015, 11:37
  Alternative to Handbrake for x264 video encoding?By thefinalprophecy in forum Video ConversionReplies: 37Last Post: 25th Aug 2013, 00:11
  analog video to x264 - Handbrake vs. StaxRip vs. VideoToVideoBy TrackingError in forum Video ConversionReplies: 3Last Post: 17th Jun 2013, 12:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
