when i play most of my vcds in WMP why do loads of sqaures come up and block the image so i cant see bits of the screen. it only happens during parts but its usually the good ones :( is it due to bad copies?
I believe that I have had the same problems as you are stating. Do the blocks sometimes turn bright green? Does your audio have pops and crackles too?
My findings have pointed to poor quality media. Once I switched to a higher quality CD-R(W), the same base file made a good VCD.
Another thing I found was that I was more likely to have a bad VCD burn if I authored the VCD using TSCV. I since use VCDEasy to do the work and have never had a bad VCD. -
the squares are usually all differnt colours and the audio stays normal. do u think that if it was bad media, could i just copy them to my HD and would that fix it?
conversion square to non square pixels???
By jakeotr in forum Video ConversionReplies: 7Last Post: 27th Jan 2012, 01:53 -
Standard (square) TV Settings
By mastershotx in forum Newbie / General discussionsReplies: 1Last Post: 11th Jul 2010, 19:47 -
Encode to non-square pixel xvid?
By rebl in forum Newbie / General discussionsReplies: 12Last Post: 6th Jan 2010, 23:11 -
should use square pixels or not for 16:9?
By j.man in forum Video ConversionReplies: 5Last Post: 4th Mar 2008, 22:28 -
back to square one. cdr source questions.
By Dr.Gee in forum MediaReplies: 2Last Post: 5th Jun 2007, 18:03
