Hi guys, I'm having an audio problem recently.
I can only hear the audio on potplayer if i connect my bluetooth earphones to my laptop.
I've tried other players such as vlc and it works fine without the earphones.
It's only with potplayer that i'm having this issue and it's my main video player so any help would be appreciated.
Thanks![]()
Have you tried audio - Output speakers 2/0/0 recommended ? But it should be default when initialize potplayer.
Check if you have something checked in Audio - System volume. Or if you have just mute potplayer (Audio - Mute)
But probably is something checked in potplayer system volume (wave is probably muted here)
Bernix -
If you're on windows 10 and had recently the creators update, seems that
it is installed with the audio device configure to use headphones.
[PotPLayer] DirectSound Audio Renderer?
By juniiflow in forum Software PlayingReplies: 0Last Post: 24th Jul 2014, 18:19 -
potplayer audio instantly out of sync
By coldstatic in forum Software PlayingReplies: 2Last Post: 10th Jul 2014, 01:41 -
PotPlayer audio crackling
By stardust018 in forum Newbie / General discussionsReplies: 3Last Post: 30th Jun 2014, 22:12 -
Potplayer audio gets distorted
By medwatt in forum Software PlayingReplies: 3Last Post: 27th Aug 2013, 19:57 -
Connecting Wireless Earphones to TV without RCA out connections
By johncar in forum Latest Video NewsReplies: 2Last Post: 4th Apr 2013, 02:44
