:D I AM LOOKING FOR ANY GOOD SUGGESTIONS ON A NEW BURNER I HAVE NERO AND ESY CD CREATOR ALREADY BUT MY TWO YEAR OLD ACER IS FAILING SO I NEED SOMETING NEW....ANY SUGGESTIONS??[/b]
Results 1 to 11 of 11
I suggest the Lite-On 24x. It has Burn-Proof, so no more coasters (A HUGE problem with the Acer 10x...not sure if that's the one you have or not...) The Lite-On 24x is only $65 on www.pricewatch.com , and it can overburn up to 99 minutes onto an overburn CD-R! And it can write on 12x media at 24x! Plextor is nice, but their 24x didn't get great reviews. It's a variable speed burner, so you really get like 21-22x, not true 24x. Their 40x is NICE, however.
:D thnx for the info i am looking at the lite-on and or the plextor the acer i have is the 4x4x32 had prob's since day one now i can play music cd's but it wont burn says empty media/no disc in the burner
I use the Yamaha CDRW 2200 E and it works fine for me. 20x10x40 if I remember right.
The Lite-On is $65, and the Plextor is $165. What's to think about? You are using a 4x now, so you are used to 20 mins to burn a CD. With a 24x, it will be about 4.5 minutes. With a 40x, it would take a little less than 3.5 minutes. With the Lite-On, you can use 8x or higher media, and still burn at 24x. With a 40x (or a 32x), you would have to get the new, specialized, high-speed media, which also means more money. Again, what is there to think about?!
THNX FOR MAKING UP MY MIND FOR ME BROCK1111......... I HAD NEVER HERD OF EITHER BEFORE SO I DIDN'T WANT TO JUMP AT THE FIRST GOOD DEAL, ALSO I AM MORE INTERESTED IN QUALITY THEN SPEED. I HAVE ENUFF COASTERZ TO LAST A LIFE TIME AND A HALF.
I LIKE THE ABILITY TO BURN ON THE 90 AND 99 MIN CDR ALSO
THNX AGAIN BACK @YA
LR (:>~ -
lrspinelli the Lite-On is better deal and all most as good as plextor drive is ever all CDRW review will tell that Lite-On is best value for money I been very happy with my Lite-On CDRW drive.
Let me tell you, I would have never in my life bough a cyberdrive, but the new ones are very nice. I now have a 36x12x48 Cyberdrive (Bought it retail with Nero 5.5 for $71). It is awesome, it burns everything and is so quite. Most people can't say that, my friend has a 24x Yamaha and you can here him burning in another room. I highly recommend you purchase it here, and look at the reviews, they have the best service, I have bought $1000's from this place:
http://www.newegg.com/app/ViewProduct.asp?submit=manufactory&catalog=5&manufactory=1580&DEPA=1 -
just because it has burn proof doesn't mean you don't get coasters as friends have found outOriginally Posted by brock4111
Either the lite on or the plextor would be a good choice but there is a reason the lite on is so much cheaper. The plextor is definintely better quality and if you ever need tech support from lite on you can forget it. the plextor 24//10/40 is probably their best so far, the 40 has new technology they havent really worked all the kinks out of yet and you can get the 24 for around $100 after the mail in rebate from plextor. (good till the end of may i think) you should really check out http://www.cdrinfo.com/ and see what they have to say about them. plus you can find a lot of people who actually own and use these drives in that forum.
What are the differences in these 2 BR Burners?
By golfnut in forum DVD & Blu-ray WritersReplies: 27Last Post: 23rd Apr 2012, 19:14 -
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
How to Burn at 16 speed or better with 4 burners
By burn master in forum User guidesReplies: 9Last Post: 30th Mar 2010, 20:49 -
are there any 4x dual layer bd burners yet
By Onceler2 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Aug 2008, 05:22 -
HD DVD Burners
By leebo in forum DVD & Blu-ray WritersReplies: 5Last Post: 22nd Feb 2008, 22:53
