Hi, I will be converting 50 VHS tapes to MP4. I do not yet know if the tapes each have 2 hours of video, or less, but there is the potential of 100 hours of VHS-quality video. My question for you all is, how large of a USB flash drive OR external harddrive do I need to fit it all?
Results 1 to 9 of 9
Hi,
it depends how you will capture these VHS. In what format and what filters will you use. VHS quality itself is very very low. Probably you will upscaling and do similar things.
Edit:I think for 100 hrs of video will be 64 GB usb stick enough. But it is my personal opinion. I think somebody will correct me.
BernixLast edited by Bernix; 18th Dec 2017 at 12:57. Reason: Edit
1)capture test 1 hour
2)check what size the file
3)multiply x100
that the size
example:
1 hour capture 3.2 GB
3.2 GB x 100 = 320 GB
Just buy Western Digital 2TB
and you will be OK -
Don't forgot actual resolution of your VHS WIKI ->
NTSC VHS is roughly equivalent to 333×480 pixels luma and 40×480 chroma resolutions
Bernix -
Bernix -
The bigger the drive, the more you can lose, "in one fell swoop", when the drive fails, , , , I woud not go more than 1TB.
Yes, no, maybe, I don't know, Can you repeat the question? -
If you capture uncompressed YUY2 (or other YUV 4:2:2) with a lossless codec you will get around 30 GB/hr. You'll need a >3 TB drive to store 100 hours and work with it. 8 TB external USB3 WD drives are now $150 at BestBuy. 4 TB drives are $90. Most buyer have reported WD Red drives inside. A pair of the latter would let you have all of your videos archived and a separate backup.
Of course, if you don't plan to save the lossless video you only need enough drive space to work with a few hours at a time. Capture, filter/encode, burn DVD, delete, repeat.Last edited by jagabo; 19th Dec 2017 at 09:50.
Can i transfer files between a harddrive and wdtv box harddrive?
By RBCC in forum Video Streaming DownloadingReplies: 1Last Post: 21st Oct 2014, 23:21 -
External Harddrive Not Recognised
By Teac23 in forum ComputerReplies: 13Last Post: 20th Jun 2014, 22:44 -
LG BP125 and WD Harddrive problems!
By Jonesy_135 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th Mar 2014, 22:06 -
rip dvd to harddrive
By defnoob81 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2013, 11:52 -
VIDEO_TS folder on harddrive?
By BaaGGHo in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2013, 00:40
