Page 2 of 2
FirstFirst 1 2
Results 31 to 32 of 32
    Aug 2013
    Central Germany
    I believe after you enabled the use of QAAC in the MeGUI options, a following update should install it there?
    Check also in the updater (by displaying all packages) if you have to enable the update of the qaac package as well.
  2. Ah yes, that sounds correct. Dank.
