hi
i copy dvd with DVD DECRYPTER
i frameserve with DVD2AVI
i encode with TMPGEnc
i get good results
dose anyone use a better encoder which is a bit faster
ALSO
WHEN I COPY IN DVD DECRYPTER THERE IS A OPTION TO MERGE VOB FILES WHAT DOES THIS MEAN I`VE DONE DVD WITH THIS OPTION TICKED/UNTICKED MAKE NO DIFFERANCE?
THANX
I copy using Smart ripper, convert using DVD2AVI and then use TMPGEnc to finish. Not much faster but it's probably the fastest way to convert DVD to VCD. To go to SVCD, you might want to try DVD2SVCD.
ALSO WHEN YOU USE THE OPTION TO MERGE VOB, DO YOU NOTICE ONLY 1 VOB FILE RATHER THAN 3 OR 4 INDIVIDUAL FILES? VOB FILES ARE ALWAYS 1GB MAX.
(PS shouting is considered rude so please don't use cap lock key next time.) -
hi i use DVDX and CCE 2.5 SP Adobe premier Plugin. It takes me 2hrs 34 min to encode the File to a VCD MPEG files for a 1hr 53 min movie. ie ratrace movie. I use CBR 1450 bitrate as it exactly fits in 2 CDS. As far as my testing over the past 11/2 years this is the fastest and best method i can find
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 17:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 20:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
