So, as usual, I go myself into something I know nothing about.
I was lent a Panasonic DVCPRO HD P2 AG-HVX200AP camera by a local TV studio to record a Christmas concert.
So, I think I have the camera figured out.
I then downloaded the drivers and was able using a USB cable to see the files on the camera.
I can see the files using explorer in Windows 10 ... separate audio and video.
Both (the audio and video files) have a MFX file extension!
I can play the audio and video separately using VLC.
So first, how do I combine the audio and video together into one file?
How do I convert MFX (or what ever I combine them into) to MP4 (or something usable)?
I want to use free (open source) software since I will only have the camera for a week then probably not again till next week.
Thanks ... Mike
Maybe MXF?. First you edit in this format before converting to a delivery format like MP4. There are free NLE editors (VSDC, Openshot, Kdenlive ...) that also can convert to MP4.have a MFX file extension!
If you don't need to edit something like Xmedia Recode can convert to MP4. -
Thanks ... Yes, MXF (sorry). As I said, I have separate audio and video files. I need to combine them then get them to MP4.
Will any of these free editors combine the two files into one?
Thanks .... Mike -
Yes. They use a time line where you can have multiple video/audio tracks.Will any of these free editors combine the two files into one?
With Xmedia Recode (XR) you drop the video onto it and import the audio on the "Audio" Tab -
Or just mux the video and audio tracks together. You can probably do this easily with ffmpeg and a batch file like:
Change the path to where ffmpeg.exe is installed on your computer. Then multi-select a video file and audio find in Explorer and drag them onto the batch file. The output file will have the same name as the first input file except with an mp4 extension. Once you have this set up it's much faster and easier than starting up an NLE, adding the sources, and saving.Code:"C:\Program Files\ffmpeg\bin\ffmpeg.exe" -i "%~1" -i "%~2" -c copy "%~dpn1.mp4"
You can also use a professional NLE in trial mode if you only need it for one time, then uninstall it ..
Agree. This is a MUCH better way of handling these P2 files as it will combine audio and video as well as stitch together long clips if necessary. You can then output whatever format you like.
Try Premiere or Davinci Resolve. (Resolve is free and you can keep it.)
Mp4 video + mp4 audio
By Igniz in forum Video ConversionReplies: 3Last Post: 28th Apr 2017, 01:58 -
Some Mp4 movie files are showing up as audio files on WD TV Live
By Sunshine Superman in forum DVD RippingReplies: 8Last Post: 21st Oct 2014, 13:59 -
fixing audio sync without changing the video/audio quality of mp4 video
By aruwin in forum AudioReplies: 3Last Post: 7th Aug 2014, 23:10 -
Merge Video from one MP4 with Audio from another MP4 - How?
By GrayStrickland in forum EditingReplies: 6Last Post: 10th Feb 2014, 04:45 -
How 2 convert MP4 w/3 audio trax+1 vid trac into MP4 w/1 audio+video trac?
By Whitezombie455 in forum Video ConversionReplies: 11Last Post: 17th Nov 2013, 02:14
