  1. I exported a vidcoder preset a few weeks back. Now I am trying to import that preset but the program is asking for an xml file while my export is a vjpreset file. Did they change the export format and if so can I convert my preset to the new format?
  2. Member Bernix's Avatar
    Apr 2016
    Europe
    Hi,
    I can't replicate your problem. I have both files in export import preset. Are you importing through Tools-import preset?
    EDIT:Maybe if you can't get over this, then recreation of preset will be easiest. You can open preset in notepad, if you do not remember settings correctly.
    Bernix
