  1. A Member since June, 2004 Keyser's Avatar
    Feb 2013
    Westernmost point of Europe
    Hi,
    Anyone knows anything (like media code and quality) about these discs?
    10 Xlayer Black Bottom Vinyl CD-R blank CD discs 48x 700MB Retro look
    Thanks.
    "The greatest trick the Devil ever pulled was convincing the world he didn't exist."
    Oct 2005
    666th portal
    can't say i'ver heard of them but i burned quite a few verbatim "vinyl" cds - https://www.bestbuy.com/site/verbatim-digital-vinyl-52x-cd-r-discs-10-pack-black-orang...?skuId=4419500
  3. A Member since June, 2004 Keyser's Avatar
    Feb 2013
    I also have those Verbatim Vinyl CD-R, but they're different. Verbatims are only black at the top (label side), which means they're not really BLACK CDs. On the contrary, the Xlayers have black dye, so they're also black at the bottom (recordable side).
    Feb 2006
    looks like a PlayStation 1 disc.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    personally i'm more concerned with how well the dye works than what color it is. i trust verbatim cdr.
  6. Originally Posted by aedipuss View Post
    CD(R) use IR - plenty IR filters is dark (black or even opaque for visible light - https://jenslabs.com/2013/03/04/diy-ir-filter/ ) i will be not surprised if black dye will be completely transparent for IR.
  7. I've used some with jet black recording sides and mirror silver tops - never had any issues with them. They are unbranded.
    Brian.
