Hello,
I used the following ffmpeg command to further compress a video:
Notice the "-2" which I read somewhere.Code:ffmpeg -i input.mkv -c:v libx264 -vf scale=720:-2 -pix_fmt yuv420p -c:a aac -b:a 128k -ac 2 -ar 44100 -threads 2 -f mp4 output.mp4
Still, the frame ratio isn't preserved (as reported by ffprobe.exe):
Is there a simple way to tell ffmpeg to not mess with the frame ratio?Code:Input #0, matroska,webm, from 'input.mkv': Metadata: ENCODER : Lavf57.71.100 Duration: 00:23:55.84, start: 0.000000, bitrate: 9229 kb/s Stream #0:0: Video: mpeg2video (Main), yuv420p(tv, top first), 720x576 [SAR64:45 DAR 16:9], SAR 1:1 DAR 5:4, 25 fps, 25 tbr, 1k tbn, 50 tbc (default) Metadata: DURATION : 00:23:55.840000000 Stream #0:1(unknown): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default) Metadata: DURATION : 00:23:55.816000000 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'output.mp4': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2avc1mp41 encoder : Lavf57.83.100 Duration: 00:00:27.20, start: 0.000000, bitrate: 600 kb/s Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 720x576 [SAR 1:1 DAR 5:4], 464 kb/s, 25 fps, 25 tbr, 12800 tbn, 50 tbc (default) Metadata: handler_name : VideoHandler Stream #0:1(unk): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 128 kb/s (default) Metadata: handler_name : SoundHandler
Thank you.
Do you really need scale? It seems to me be redundant.
I think -2 means the resulted height will be even number. (I think) -1 means keep aspect ratio when resizing.
But scaling seem to be here as I mentioned above, try setdar=16/9 to your command line to be sure it is 16/9 set.
BernixLast edited by Bernix; 15th Dec 2017 at 08:13.
Thanks.
Yes, I do need it, because the output looks weird. The original is at the top:
Here's the command I used:
---Code:ffmpeg -i input.mkv -c:v libx264 -vf setdar=dar=4/3 -vf scale=720:-1 -pix_fmt yuv420p -c:a aac -b:a 128k -ac 2 -ar 44100 -threads 2 -f mp4 output.mp4
Edit: Found it. It was "setdar=16:9":
Thank you.Code:ffmpeg -i input.mkv -c:v libx264 -vf scale=720:-1,setdar=16:9 -pix_fmt yuv420p -c:a aac -b:a 128k -ac 2 -ar 44100 -threads 2 -f mp4 output.mp4
There's still a bit of a problem: How can I get rid of the black bars on both sides?
Why don't you just specify the height along with the width?
Or if you're too lazy to figure out the height use the negative modulus as indicated earlier.Code:-vf scale=720:404
ffmpeg vs ffprobe frame count speed
By Anime4000 in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2019, 06:05 -
Use ffmpeg to replace frame with previous frame if frames are X % different
By dkrichards16 in forum Video ConversionReplies: 0Last Post: 29th Apr 2017, 17:27 -
Preserving anamorphic aspect ratio while cropping
By ackboo in forum Newbie / General discussionsReplies: 20Last Post: 29th Apr 2015, 10:36 -
FFMPEG error: first frame is not keyframe
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2013, 16:37 -
ffmpeg frame grab question
By johnp12 in forum Newbie / General discussionsReplies: 1Last Post: 21st Jul 2013, 18:16
I though that semicolon is colon
