I have a few MKV files with AC3 audio that I want to be able to play on a Roku using the Plex channel. Unfortunately, Roku does not support AC3, so Plex tries to transcode this, but ultimately fails.
I want to preserve the integrity of these MKV files, especially the video quality. I came across some threads that suggested using VLC to strip the audio (which I did to MP3) and then add that back into the MKV file using MKVToolNix, but when I did that, it generated a file with audio out of sync with the video.
Is there a good way to go about accomplishing what I'm trying to do? Is it even possible to create a good-quality audio file of a different format from an MKV and repack it into the original MKV?
Thank you for any and all help!
Did you account for any audio delay in your original mkv file?
What does that mean, 'ultimately fails? I've played a ton of MKVs with AC3 audio from my computer through the Plex channel on my Roku box to my television. And, as jagabo says, if you wind up with a delay for some reason, account for it when remuxing as MKV or whatever.
I didn't account for audio delay, and I suppose that I could have converted the audio from the MKV to MP3 without accounting for the frame rate too, which I saw on another thread. But another user on the Plex forums mentioned that there was a simple solution using Xmedia Recode.
Originally Posted by JuiceWSA
BATCH remove audio track from mkv
By MarquisdeOz in forum AudioReplies: 53Last Post: 30th Jul 2018, 08:48 -
Merging MKV extracted files to playable MKV video file
By deepfrayder in forum EditingReplies: 9Last Post: 12th Dec 2017, 23:17 -
MKV video/audio not in sync for added audio track
By paolone67 in forum EditingReplies: 2Last Post: 1st Sep 2014, 11:21 -
MKV Audio track help
By theaminator19 in forum AudioReplies: 1Last Post: 13th May 2014, 14:35 -
mkv replacing audio track and out of sync
By chaussettdeguerr in forum EditingReplies: 6Last Post: 25th Mar 2013, 22:42
