Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Results 1 to 25 of 25
  1. hi i hope this is the right place for thread
    i have full bluray movie and i delete some audios with BD-RBV05025
    then i did burn it on blu ray disc 25GB with ImgBurn when it's burning i get error
    i tried to play it on player its runing but when reach in 1:62 stop
    in this time just stop
    https://imgur.com/4fjgx1d
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Cinavia protection ? ?
    BeyonWiz T3 PVR ~ Popcorn A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 64bit ~ Yamaha RX-A1070 ~ QnapTS851-4G
  3. Originally Posted by netmask56 View Post
    No when its reach to 1:62 the image stop
    Feb 2006
    what did you use to copy the movie ??
    when burning try burning at 4x speed.
  5. Originally Posted by october262 View Post
    the problem is after i remove the audio
    i use BD-RBV05025 for remove audios
    is there any other program for remove audio
    Sep 2011
    You should be able to remove any audio language you don't want with BDRebuilder, Cinavia usually doesn't kick in until about the 20 minute mark but I'm not sure about using any of the new players.
    Feb 2006
    what is the movie doing, freezing up ??
    if the movie stops then it may be a bad disc or a form of copy protection.
    what is the name of the movie ??
  8. Originally Posted by october262 View Post
    Yes it's freezing on player
    No after i delete the audio i play it on my laptop and its work but i don't know what happened to image in some moment
    Before i delete the audio was no problem
    so the problem after i delete audio
    Feb 2006
    try doing a firmware update for your bluray player.
  10. Originally Posted by october262 View Post
    The problem is after delete audios so there is no problem with player
    Feb 2006
    what brand of blank discs are you using ??
    you might also try this - start imgburn - click tools - settings - write - page1, and checkmark " perform OPC before write "
    click ok and try burning your disc again
    Sep 2011
    Did you delete the audio with BDRebuilder after you burn the disk or before? Try deleting the audio with the movie on your hard disk first, You could burn a disk with the audio then remove audio with BDRebuilder then burn it, Do all this with the movie on your hard disk, If it doesn't work then I would think the problem could be with BDRebuilder.
  13. Originally Posted by tarzan54 View Post
    I Did like what u say but the out put has problem
    yes it is the problem with BDRebuilder
  14. i think i find the problem
    the problem was because i choose output target 23GB like my BLURAY disc space
    the movie is 31 GB and if i remove audio i will get 27GB = That u can NOT burn it on blu ray disc 25GB
    Sep 2011
    Exactly, I'm surprised it would even let you burn it that way, The program you used to burn it should have popped up with a warning, Shrink movie down to a 25gb disk and you should be fine.
  16. Originally Posted by tarzan54 View Post
    No you can not burn that move
    because the size of the movie
    is there any other way to burn that movie on 25GB Disc ?
    Feb 2006
    run the movie through a program like dvdfab which has the ability to shrink/compress the movie so it can be burnt
    to a 25 GB disc.
  18. I'm a Super Moderator johns0's Avatar
    canada
    Better to use vidcoder to re-encode the movie,way better than dvdfab.
    Sep 2011
    I always use BDRebuilder to shrink to a 25gb disk, I think it is the best and free but you can donate to the developer for all the hard work he does.
  20. Originally Posted by october262 View Post
    to a 25 GB disc.
    Dvdfad is not free
    Sep 2011
    No it isn't, not for what you want to do, I would buy AnyDVD HD, It costs a little under $4 a month for a year subscription and I haven't had any problems with it, Copy movie to hard drive with it then run movie through BDRebuilder, Doesn't get any easier in my opinion.
  22. I'm a Super Moderator johns0's Avatar
    canada
    I don't like BDRebuilder for the fact that it requires that you have ffdshow installed which i never use and don't need and i can encode all formats without the need of it.
  23. Video Restorer lordsmurf's Avatar
    I've been using MakeMKV to archive my BDs. Much better solution.
    I'll re-encode with Hybrid once ripped.
  24. Originally Posted by lordsmurf View Post
    I want to burn it on bluray
    so is MakeMKV can make BDMV ?
  25. Member
    Sep 2011
    I don't think it does, but you can always use TsMuxer to create a Bluray folder then burn it.
