About how much does it usually cots per movie?
I have a very collection of movies and some of them give read errors when I try to back them up.
They are from different studios.
Does anyone have some links to the different studio's replacement pages?
Every time I try google of any other search engine I get pages about how 4k is to be the next big thing.
Aldo can someone suggest for specific searches?
Thank you.
Results 1 to 11 of 11
If it play on a standalone player with the current updates than that's the protection doing it's "job". If not and there is no user caused damage to the disc try contacting the studio it was made at via their contact us page. They may ask you to send the old disc to them. This happened when star trek the next generation season 1 on bluray first came out. Not being able to rip on a PC drive is NOT a valid defect.
if all else fails read the manual -
The reason that I am trying to copy them is because they DO NOT work in a real player but there is no sign of physical damage.
I had this issue with my copy of Maniac Cop 2 on bluray. The disc had no physical problems and played fine, and yet, about halfway through the backup process both dvdfab and anydvd HD would start throwing up errors. It was impossible to back it up. I eventually just had to purchase another copy from Blue Underground.
Why not try MakeMKV - it doesn't alter the files just puts the titles in a MKV container. Doesn't shrink the size but maybe once you have the MKV you can process it to be smaller if that's what you need.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
If you have so many discs from so many sources failing -- the problem probably isn't the discs.
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 08:32 -
Anyone using BD XL 100GB Blu-ray discs?
By redwudz in forum MediaReplies: 0Last Post: 19th Aug 2016, 07:57 -
LG blu-ray player is stopping playing blu-ray discs
By mausinho in forum DVD & Blu-ray PlayersReplies: 2Last Post: 22nd Feb 2016, 09:55 -
Blu-ray replacement coming in 2015
By nic2k4 in forum Latest Video NewsReplies: 63Last Post: 6th Apr 2014, 02:48 -
No sound from blu-ray discs.
By Jammers in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Aug 2013, 13:33
