    Dec 2002
    Please excuse my nievity, but I have ripped an original DVD using Shrink so that I can convert them to format to enable me to put them on a portable HDD and the plug it into my TV.
    My TV Supports a lot of formats, what would be the best in terms of quality to convert the vob files to, and the best settings. The video content is motorsport rather than slow shots etc etc, I have tried using DVDfab to MP4 format but seem to get pixelated results on the faster movement of the video...would MKVbe a better format
    Any info or advice would be great.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Next time skip DVDShrink and use MakeMKV.
  3. ½ way to Rigel 7 cornemuse's Avatar
    Mar 2014
    Cyber Dystopia
    Which formats does your tv support??
    If it supports VOB's, you're home free, , , ,
    My media player supports lots of formats, I prefer iso images of dvds, , , ,
    Yes, no, maybe, I don't know, Can you repeat the question?
  4. MP4 and MKV (along with AVI, MPG, TS, MOV, etc.) are "containers" -- logical boxes that hold video, audio, and other data. The container does not effect the quality of the contents. Within the container video and audio can be compressed with any of a large number codecs (COmpression, DECompression methods). It's the quality of the source video/audio and the codecs (and the settings used with those codecs) that determines the quality of the contents.
    MakeMKV will re-mux the MPEG 2 and AC3 audio from your DVDs into an MKV container. There will be no change in quality and not much change in file size. Whether your TV can play it is another issue.
    Dec 2017
    Cologne
    I have a similar problem. I used DVD Shrink to convert it into vob files and makemkv to mkv files.
    After this the mkv file is not playable on my two LG TV´s.
    So I demuxed und muxed it again with mkvtoolnix and it is playable.
    On one LG it is working fine, the other LG does not fill the screen (Fullscreen enabled) so i checked the header of the mkv file with one that works fine corrected some settings (video display heigh and width) and now the height is working fine but not the width.
    Any ideas?
