Hello - I know questions like these are asked a lot, but I have a slightly tricky issue.
I have about 30 video+audio files that have been captured incorrectly. They are mp4 H.264 with stereo AAC audio.
The video is fine and I don't want to re-encode that. The stereo audio is about -20db on the right leg.
What would be syntax of a windows FFmpeg command be to copy the video and left stereo audio leg and add 20db gain to the right leg only to a new file?
Any guidance much appreciated.
Thanks all - Duncan.
Try:
for %%a in (*.mp4) do ffmpeg -i %%a -c:v copy -af dynaudnorm=n=0 "output\%%~na.mp4"
That should normalize the channels independently (to same level). If you want to do a "stupid" gain you probably have to split the channels and then do the "normal" gain or normalization filter.
Are they "real" stereo files? If they are not I would just convert to mono, or stereo but just by duplicating the left channel.
https://superuser.com/questions/323119/how-can-i-normalize-audio-using-ffmpeg
https://trac.ffmpeg.org/wiki/AudioVolume
https://trac.ffmpeg.org/wiki/AudioChannelManipulation
https://ffmpeg.org/ffmpeg-filters.html#dynaudnorm -
**really helpful** thanks you. For my purposes this approach worked just great.
For anyone in a similar situation, I had to make one tiny adjustment to increase the gain range to 20db
ffmpeg -i %%a -c:v copy -af dynaudnorm=n=0:m=20.0 "output\%%~na.mp4"
Your expertise is much appreciated.
Newbie needs help with recompile ffmpeg
By ramsh in forum Newbie / General discussionsReplies: 0Last Post: 5th Jul 2017, 05:03 -
FFMPEG - X265 - Help for correct commands and syntax
By AllThatEvil in forum Video ConversionReplies: 16Last Post: 22nd Mar 2017, 17:04 -
ffmpeg command line syntax
By sambat in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2016, 20:01 -
Q: ffmpeg syntax for VC1 to H.264?
By DanielCoffey in forum Video ConversionReplies: 2Last Post: 27th Apr 2016, 15:56 -
A little confused on ffmpeg syntax with regards to the "-q" parameter.
By Iced Coffee in forum Video ConversionReplies: 4Last Post: 21st Jan 2013, 01:04
