Okay, so I've got an entire collection of movies in .avi format that my friend gave to me when he moved out of state. I want to make some of them into VCDs, unfortunately the resolution isn't very good. Is there any way to upgrade these poor quality movies? Perhaps some software tool that could help me out?
You can't improve the quality of the video much at all. Others may explain why, but you aren't going to be able to improve them to any appreciable degree. Bad source = bad end product.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Increasing resolution IMO has the opposite effect. If you increase the resolution of that's say 352:288 video to 400:576 your final video will
not gain any quality. It would just make your file larger and would look much worse on TV or PC screen. The only thing you can do is to use a video editing program to add filters to the video and save to a new video at the same resolution.Winners never quit, quitters never win. Those who never win and never quit are idiots. -
Think of it like this:
If you have a shabby-looking still image or a low-quality audio file, you can work on them all day with tools such as Photoshop/Paint Shop Pro (images) or SoundForge/CoolEdit (audio) and you can make them look/sound different (contrast and color adjustment, artificial stereo and reverb, ad infinitum, ad nauseaum), but you really can't get back what has been discarded. If the movie was encoded in a way that made it look worse, in order to save encoding time or disk space, you "can't make a silk purse from a sow's ear". Besides DivX (I assume the AVIs are DivX) is a "lossy" compressed format. Every time you re-encode it, you lose information.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Well, you can, but I wouldn't advise it... Thanks for your help, guys. I'm not sure what I'll do but at least I now know I can't upgrade it any.
How to increase resolution in GUI for dvdauthor, please?
By Centauri39 in forum Authoring (DVD)Replies: 21Last Post: 12th Mar 2021, 18:49 -
AVI file volume increase.
By seven1970 in forum AudioReplies: 8Last Post: 31st May 2013, 17:07 -
convert compressed avi files to mpeg without increase in file size?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 7Last Post: 2nd Nov 2011, 06:29 -
how to increase volume of a mkv file
By wolvie77 in forum AudioReplies: 3Last Post: 8th Nov 2010, 15:54 -
how do i increase my video resolution to 720p with my 680p?
By lucchini in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2010, 17:14
