Results 1 to 9 of 9
    Dec 2017
    Moscow
    Hi guys!
    I usually use Subtitle Edit and everything`s fine but today I`ve encountered a problem. I click on the "Add a waveform" field, there goes a process but nothing happens. The field remains black, no waveform. Could you help me with it?
    Aug 2010
    San Francisco, California
    Post a MediaInfo report on your video file.
    Dec 2017
    Moscow
    Is it enough?
    Aug 2010
    You have two audio tracks to choose from. If you use the VLC player instead of DirectShow, you should get a track selection item in the Video menu.
    Dec 2017
    Moscow
    There are actually four audio tracks. I tried VLC but still nothing.
    Aug 2010
    I think you'll have to contact Nikolaj at his blog: http://www.nikse.dk/Mobile/AllBlogEntries/.
    Dec 2017
    Moscow
    Thanks ) I did.
  8. And yet the solution is simple.
    Copy the folders from an earlier version.
    i.e. I had SE351 installed and copied the folders: Waveform and Spectograms to the folder where SE356 is installed.
    Problem Solved.
    May 2024
    Turkey
    Originally Posted by AllaRosie View Post
    Thanks ) I did.
    Hi there. How did you solve the problem?
