i have an .ASF taken from a camera that i want to deshake ...
most editors l've tried says it's 30fps but not avidemux (and some other editor i can't remember)
General
Complete name : E:\ASF\FNM_Jam06.ASF
Format : Windows Media
File size : 616 MiB
Duration : 24 min 12 s
Overall bit rate : 3 559 kb/s
Maximum Overall bit rate : 3 731 kb/s
Encoded date : UTC 2017-11-03 11:30:33.490
Video
Format : MPEG-4 Visual
Codec ID : M4S2
Codec ID/Hint : Microsoft
Description of the codec : mpeg4z
Bit rate : 3 365 kb/s
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.365
Stream size : 583 MiB (95%)
NumberOfFrames : 43556
Audio
Format : ADPCM
Codec ID : 2
Description of the codec : adpcm_ms
Bit rate : 44.1 kb/s
Channel(s) : 1 channel
Sampling rate : 11.025 kHz
Bit depth : 4 bits
Stream size : 7.64 MiB (1%)
even mediainfo says it's not variable frame rate ..shoud i just ignore that?
anyway my main concerne is deshaking... this clip has it all ...fast pans, zooms, tilts all over the place
with a good first pass deshaker setup should really help me ..i know it won't be perferct
i've read that pushing contrast and brightness may help detection..
i'm willing to do a few tries and do a best of master track of my tests ..
my second option is to go into my pocket and buy something like Magix movie edit pro or Cyberlink powerproducer i think both have proDAD mercalli V2 included..
what do you think?
Never mind. Wrong thread.
- My sister Ann's brother -
Actually the original question I edited belonged elsewhere, but I guess it does apply somewhat here. I'm using FFMS2 and LSMASh and can't get a clean decode for either of the mp4 samples -- broken frames, frozen frames, blank frames, pixel blocks, etc.,etc. Maybe others have the same problem, I'll just wait and see.
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 05:19 -
Megui 1 pass vs 2 pass for 480p->720p anime ,difference
By zanzar in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2016, 14:47 -
VFR to CFR
By SameSelf in forum Video ConversionReplies: 6Last Post: 7th Jun 2016, 19:46 -
Video indexing
By xam1937 in forum Newbie / General discussionsReplies: 1Last Post: 9th Mar 2016, 02:16 -
What's the difference between 2nd pass and two pass in h.264 encoders?
By Stears555 in forum Video ConversionReplies: 1Last Post: 26th Sep 2013, 05:09
