Hello,
I was going to record a TV show so that I would watch it later and sadly I didn't know that it was on till I started watching it (Someone else in the house told me). Anyhow I saw that you can watch it online and I managed to download the file but I am unable to convert it or watch it with VLC player.
Here's the mediainfo that I got from the file:
Could someone please tell me what I would need to conver it? I tried Free FLV to MP4 Converter and that failed to load the file and I can't play it in vlc.General
Complete name : C:\Users\Daniel\Downloads\Video\War On Waste - Series 1 Ep 4 Turning The Tide - ABC iview.FLV
Format : Flash Video
File size : 649 MiB
Duration : 59 min 48 s
Overall bit rate : 1 516 kb/s
Video
Bit rate : 1 322 kb/s
Width : 1 024 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Bits/(Pixel*Frame) : 0.090
Stream size : 566 MiB (87%)
Audio
Bit rate : 128 kb/s
Sampling rate : 44.1 kHz
Bit depth : 16 bits
Stream size : 54.7 MiB (8%)
Thank you
Hi friend, it has been several day ago. Maybe your problem has been solved already. But I still want to post my idea here.
You convert your FLV to MP4 with the free video converter? Then that means MP4 still can't be played on VLC. Maybe you can try following steps:
1. Go to VLC on your computer and disable hardware video decoding.
2. Go to Tools > Preferences on your computer in VLC and check the following settings by turn.
3. VLC is a free media player available from VideoLAN, which regularly updates program to support more formats so as to provide a better user experience. To solve "VLC Won't Play MP4 video files" issue, you can check whether you are using the latest version of VLC. If not, just update the program by visiting VLC official site for download.
4. Use other free online converters like KeepVid to convert FLV to MP4. If the problem still exists, try the dedicated one like Cisdem Video Converter to convert FLV to other VLC supported formats. -
Tubedigger ($15) downloaded the video no problem. Link to video ( I chose 640x360):
https://files.videohelp.com/u/61125/au.mp4
Strange thing is the video initially wouldn't play on Windows 8 vlc. I downloaded mpc-hc and the video played fine on that, then I tried again with vlc and it played fine. I put the video on Android device and it wouldn't play on the stock media player, but it played fine with vlc, although once I got a notice something about hardware acceleration error. Video also played fine on standalone media player and Windows xp vlc. There must be something a little strange about the specification of the video, but I don't know what it is, or how to correct it.Last edited by jimdagys; 20th Dec 2017 at 21:04.
General questions about playing torrent video that is 95.3% downloaded
By jimdagys in forum Software PlayingReplies: 2Last Post: 2nd Dec 2016, 15:51 -
Having trouble playing an .mp4 file...
By Fortesque in forum Software PlayingReplies: 7Last Post: 14th Aug 2016, 01:55 -
Trouble Playing Recovered Videos from Iphone
By dustanb_11 in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2015, 11:44 -
Playing downloaded 1080p movies on usb through TV!!!
By Mikey corrupt in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2013, 03:53 -
problem in playing flv and mp4 downloaded from youtube
By bp18449 in forum Software PlayingReplies: 6Last Post: 26th Jun 2013, 15:43
