I recently bought a hauppauge wintv pci card and was wondering waht the best program would be to capture tv shows using the huffy codec. I keep hearing about virtualdub and avi io but i see that they dont support the wdm drivers. Does anyone have any experience with IUvcr? Or if there is another way to capture I would love to hear it. Thanks, Rob
Rob,
I use the a NVidia Personal Cinema card (packaged by Visiontek), which uses WDM drivers. I capture using Virtualdub and Huffyuv and PICVideo with no problems. -
maybe its me, but isnt nvidia's personal only going to work with nvidia cards? why would it work with a wintv card? or could DVWannaB be on to something new?
LoL monsoon01 look like DVWannaB don't know any anything.
RobDMB yes iuVCR is very nice app. -
Ahhh, fellas, put on your reading specs and re-read my post. All I was suggesting is that Virtualdub does work with WDM drivers. Not suggesting that his card should work with Personal Cinema.
Cheers! -
DVWannaB, i think your wrong again, virtualdub works with WDM if you use a wrapper, so yea, or thats what i've heard around these forums.
Monsoon,
You are probably correct there. On my system, in Virtualdub, when you view capture device, it states "xxxxx WDM capture xxxxx". Maybe the card has a built-in wrap-around. I dont know that for sure.
Cheers.
Simple DV capture program
By HDClown in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jul 2010, 08:49 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 02:48 -
Best Capture Program???
By Dom_Sisko in forum Capturing and VCRReplies: 2Last Post: 11th May 2008, 21:49 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 15:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 11:20
