Does anyone know how to play those files with mplayer?
On ffmpeg I can play such files by adding '-enable_drefs 1', but I don't know of any way to do this with mplayer.
works fineCode:ffplay -enable_drefs 1 "camb_730_Mackay2_2002(1).mov"
gives me:Code:mplayer.exe "camb_730_Mackay2_2002(1).mov"
Seeing the statement 'Set enable_drefs to allow this.' I'm a bit lost, since I have no clue how to set this option in mplayer.Code:MPlayer SVN-r38006-7.2.0 (C) 2000-2017 MPlayer Team Playing camb_730_Mackay2_2002(1).mov. libavformat version 58.2.100 (internal) libavformat file format detected. [mov,mp4,m4a,3gp,3g2,mj2 @ 018de040]Skipped opening external track: stream 0, alias: path='/VibrintAVFiles/P2 News Ingest/camb_730_Mackay2_2002(1).vmf/video.vid', dir='camb_730_Mackay2_2002(1).vmf', filename='video.vid', volume='default', nlvl_from=1, nlvl_to=1.Set enable_drefs to allow this. [mov,mp4,m4a,3gp,3g2,mj2 @ 018de040]Skipped opening external track: stream 1, alias: path='/VibrintAVFiles/P2 News Ingest/camb_730_Mackay2_2002(1).vmf/audio_0.pcm', dir='camb_730_Mackay2_2002(1).vmf', filename='audio_0.pcm', volume='default', nlvl_from=1, nlvl_to=1.Set enable_drefs to allow this. [mov,mp4,m4a,3gp,3g2,mj2 @ 018de040]Skipped opening external track: stream 2, alias: path='/VibrintAVFiles/P2 News Ingest/camb_730_Mackay2_2002(1).vmf/audio_1.pcm', dir='camb_730_Mackay2_2002(1).vmf', filename='audio_1.pcm', volume='default', nlvl_from=1, nlvl_to=1.Set enable_drefs to allow this. [mov,mp4,m4a,3gp,3g2,mj2 @ 018de040]Skipped opening external track: stream 3, alias: path='/VibrintAVFiles/P2 News Ingest/camb_730_Mackay2_2002(1).vmf/audio_2.pcm', dir='camb_730_Mackay2_2002(1).vmf', filename='audio_2.pcm', volume='default', nlvl_from=1, nlvl_to=1.Set enable_drefs to allow this. [mov,mp4,m4a,3gp,3g2,mj2 @ 018de040]Skipped opening external track: stream 4, alias: path='/VibrintAVFiles/P2 News Ingest/camb_730_Mackay2_2002(1).vmf/audio_3.pcm', dir='camb_730_Mackay2_2002(1).vmf', filename='audio_3.pcm', volume='default', nlvl_from=1, nlvl_to=1.Set enable_drefs to allow this. [mov,mp4,m4a,3gp,3g2,mj2 @ 018de040]Protocol name not provided, cannot determine if input is local or a network protocol, buffers and access patterns cannot be configured optimally without knowing the protocol [mov,mp4,m4a,3gp,3g2,mj2 @ 018de040]Could not find codec parameters for stream 0 (Video: dvvideo (dvpp / 0x70707664), none, 720x576, 28800 kb/s): unspecified pixel format Consider increasing the value for the 'analyzeduration' and 'probesize' options [lavf] stream 0: video (dvvideo), -vid 0 [lavf] stream 1: audio (pcm_s16le), -aid 0, -alang eng [lavf] stream 2: audio (pcm_s16le), -aid 1, -alang eng [lavf] stream 3: audio (pcm_s16le), -aid 2, -alang eng [lavf] stream 4: audio (pcm_s16le), -aid 3, -alang eng VIDEO: [dvsd] 720x576 24bpp 25.000 fps 28800.0 kbps (3515.6 kbyte/s) <vo_directx><ERROR>Your card doesn't support overlay ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family libavcodec version 58.3.102 (internal) Selected video codec: [ffdv] vfm: ffmpeg (FFmpeg DV) ========================================================================== Clip info: creation_time: 2017-02-19T23:28:09.000000Z Load subtitles in ./ ========================================================================== Opening audio decoder: [pcm] Uncompressed PCM audio decoder AUDIO: 48000 Hz, 1 ch, s16le, 768.0 kbit/100.00% (ratio: 96000->96000) Selected audio codec: [pcm] afm: pcm (Uncompressed PCM) ========================================================================== AO: [dsound] 48000Hz 1ch s16le (2 bytes per sample) Starting playback... A: 0.0 V: 0.0 A-V: 0.000 ct: 0.200 0/ 0 ??% ??% ??,?% 0 0 Exiting... (End of file)
-> So if anyone knows how to do this or play such files with mplayer please help.
Thanks!
Cu Selur
Ps.: Background: A user asked me (see: https://forum.selur.net/showthread.php?tid=162) whether I could add support for this in Hybrid which is why I'm looking into it.
PPs.: Also looking for a way to open such files in Avisynth&Vapoursynth, so if anyone can help in that regard please do.
PPs.: adding 'enable_drefs=1' to mplayers 'config' file doesn't help either
Results 1 to 1 of 1
.MOV files won't play on windows media player
By jyeh74 in forum Video ConversionReplies: 32Last Post: 30th Oct 2017, 05:40 -
PLEASE HELP! How to play high compressed MOV files on windows 10
By dimondia in forum Software PlayingReplies: 1Last Post: 22nd Jan 2017, 07:12 -
Format Mini SD Card Problem (Can't play MOV files after Recovering)
By notjohn in forum Newbie / General discussionsReplies: 9Last Post: 28th Jul 2014, 18:18 -
MPlayer playing mpls files, how?
By Selur in forum Software PlayingReplies: 7Last Post: 6th Sep 2013, 12:27 -
How to play .mts files on tv from an external drive w/o pauses btw files?
By Delmaro313 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Mar 2013, 08:20
