HI all,
some advice please.
I have a project in Premiere Pro. The source files are 25fps. My target is a USA compatible DVD.
Should I change my Premiere Sequence settings to 23.976 and export an muxed mpeg2 for author with DVD Santa or keep 25fps and choose NTSC in DVD Santa.
Any advice is most appreciated.
				Results 1 to 12 of 12
	“He who makes a beast of himself gets rid of the pain of being a man.”
	If the PAL source is 25p you can use DGPulldown to add pulldown flags to 59.94 fields per second. You won't need to reencode the video or change the audio length.
	Unless it's 720x480 already, he will, for NTSC DVD.
 But if it's being worked on in Premiere Pro, doesn't that, by definition, mean reencoding? And if it's interlaced (although it shouldn't be if he's asking about 23.976fps), then DGPulldown isn't called for.
	First , is the footage interlaced? Confirm of deny that, it is quite important. If yes, you just cannot do it decently or somehow well directly in Premiere. NLE cannot resize interlaced footage properly and on the top of that change frames per second.
 If yes,then there is a problem. Same old, same old. Best to do it outside of Premiere. Using free software for example,
 First exporting from Premiere AC3, dolby digital audio, DVD compatible. Then exporting some lossless avi . Loading that AVI into Avisynth, QTGMC bob deinterlace it to 50p, resize it to 720x480, change those 50fps to 59.94 using convertFPS("ntsc_double"), re-interlace it again, and encoding script to interlaced m2v video (using HcEncoder for example, DVD compatible stream. Then authorize DVD from those streams.
	Ok thanks a lot guys.
 AI, I dont want to get my hands that dirty. I don't have the time. But thank you for the detailed workflow.
 What is the worst that can happen if i export the project from Premiere with TV Standard set to NTSC which by default is 23.976 in Premiere(it can be toggled to 29.97) and author a DVD using DVDSanta with NTSC in settings?
 My source footage is documentary quality, pretty rough, so this doesn't have to be perfect. I just need something that is playable and not so stuttery as to look unprofessional.
 Once again thanks for the responses guys.“He who makes a beast of himself gets rid of the pain of being a man.”
	If that means you don't want to, or don't know how to, determine if the footage is interlaced or progressive, then you can screw it up royally by choosing the wrong framerate. I don't (and won't) use either of the two programs you're using so more precise than that I can't be. You could always make available 10 seconds or so from the source so we can have a look.
	Give AVStoDVD a try, does a pretty good job creating NTSC interlaced from PAL interlaced.
 Here's a sample I encoded from a 1080i 25 fps sample I found on the 'net
 Set NTSC in the preferences and save. Then add your source to the project.
 Pretty slow going on my old AMD FX 4300, about 6 FPS but I think the results are worth it.
 Need to have Avisynth 2.6x installed for AVStoDVD.
	So many cool people ready to help. Thank you all.
 My footage is 1920x1080 / 25fps / Interlaced Upper.“He who makes a beast of himself gets rid of the pain of being a man.”
	That info won't help much. It could be 25fps PAL progressive encoded as interlaced (25p at 1920x1080 is not valid for Bluray). It could be film with some form of pulldown, which is progressive video with periodic interlaced frames and encoded as interlaced. It could be 23.976 or 24fps film original progressive, speeded up to PAL 25fps and encoded as interlaced. It could be a lot of things. Manono is correct in asking for a sample.
 And I guess you know that 1920x1080 won't work for DVD.- My sister Ann's brother
  Different Authoring sources, playback issuesBy _brice in forum Authoring (Blu-ray)Replies: 6Last Post: 19th Feb 2016, 05:21
  DVD AuthoringBy Tafflad in forum Authoring (DVD)Replies: 20Last Post: 14th May 2015, 17:24
  Floods sweep across midwest states as rains swamp Missouri and IllinoisBy enim in forum Off topicReplies: 3Last Post: 4th Jul 2014, 12:15
  DVD AuthoringBy iLegend X in forum Authoring (Blu-ray)Replies: 5Last Post: 4th Feb 2014, 05:58
  console type blu-ray recorders, are any for sale in United StatesBy for fair use in forum Newbie / General discussionsReplies: 4Last Post: 11th Jan 2013, 19:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
