Results 1 to 12 of 12
Do you want to hardcode it? You could use Xmedia Recode for that or if you mux it into the MKV file with MKVToolnix GUI you could use HandBrake/Vidcoder.
I have found best way to hardcode subtitles to video with ěščřžýáíé and other language specific symbols in potplayer. You have great control on size, color, background of subtitles, shadows and almost everything you can imagine. But it has one very big ?drawback? or disadvantage. You have to play whole video at standard speed, so for usual 90min long video it becomes almost useless because of time. On other hand in Xmedia recode I was very disappointed with result. Not special characters and not any way to proper adjust size position (at least I don't figure it out)
Bernix -
Maybe it was coded at 1250 not in utf-8 or similar. Don't remember correctly.
Nothing special
1 Dragged the video onto Xmedia Recode
2 Used the "Import" button on the Subtitle tab to open the subtitle file
3 Pressed the Arrow button to include the subtitle in the Output and Added it to queue and encoded. -
In some (most) encoders, the size of your font specified in ssa will look larger or smaller depending on the size of your video. It will look smaller in a 1280x720 video than it does in 854x480.
It's like picking a larger resolution on your PC screen. The letters get smaller and vice-versa. If you change the font size in your ssa, the subtitles should get larger, for that particular aspect of that video..
One way to correct this and make the font correspondingly the same aspect as your video is make sure PlayResX and PlayResY = 0:
PlayResX: 0
PlayResY: 0
If you have a setting like :
PlayResX: 0
PlayResY: 480
It will make a drastic difference in the size of your font, depending on the size of your video.
Videobruger did it correctly by setting those settings to:
PlayResX: 1280
PlayResY: 720
Which are also the aspect of his finished video. These settings, which are often over looked, can play havoc with size and position of subtitlesLast edited by Budman1; 4th Dec 2017 at 01:07. Reason: Unclear and incomplete description
Adding tracks to existing MKV file with MKVMerge
By pstnn in forum Video ConversionReplies: 4Last Post: 27th Aug 2017, 16:55 -
Take permanent subtitls out of mkv
By RBCC in forum SubtitleReplies: 3Last Post: 28th Oct 2015, 17:36 -
adding permanent subs to mp4
By xtwist3dx in forum Newbie / General discussionsReplies: 15Last Post: 18th Mar 2014, 19:28 -
Any good software for adding permanent subtitle to a mp4 video?
By netcat in forum SubtitleReplies: 2Last Post: 26th Nov 2013, 17:22 -
Problem adding .ass subtitle file into mkv with mkvmergeGUI
By Imationer in forum SubtitleReplies: 0Last Post: 31st Mar 2013, 13:24
