I don't notice the audio buzz when there is audio playing, but I can hear it when there is silence. Right now I am using a Digital8 camcorder for converting my Video8 tapes. It also did the same thing with a Hi8 camcorder that I tried before. Is there any way to get rid of it, or is it suppose to be like this?
Results 1 to 12 of 12
Sounds like 60 Hz ground loop noise. Try powering your computer, capture device, and camcorder all from the same power strip.
I just tried it with both my AG-1980 and TRV-350, and they both have the same problem. However, when I plug earphones into the phones jack in the AG-1980, then there is no buzz. The TRV-350 doesn't appear to have a phones jack.
If you have any other equipment connected to the computer or camcorder (especially cable TV coax) remove it and see if the situation improves.
There is nothing else plugged into it. Also, the Diamond VC500 makes a high-pitched sound when no audio or video cables are plugged in.
Not sure what would cause that ~8000 Hz whine (on top of the 60 Hz powerline noise).
The powerline noise seems to go up to like 2000 hz. I really don't know how I can get rid of it in the capture process.
The powerline noise is at 60 Hz. But it's not sinusoidal so it has overtones at higher frequencies. If you can't eliminate it during capture you can use something like Audacity's noise reduction filter to reduce it and the 8 KHz whine. But both may be at a tolerable level during normal video.
It might just be a matter of an automatic gain control boosting very low level noise up to audible levels. If that's the case it may not be an issue when you capture material with normal audio. See if you can disable any automatic gain control for the audio.
Where is the automatic gain control? I've noticed that the buzzing sound goes away when I disconnect the S-video cable, but then I only have audio.
Best method of removing buzz from captured audio
By snafubaby in forum CapturingReplies: 4Last Post: 31st Jan 2016, 19:46 -
Audio buzz on zoom
By LabanB in forum AudioReplies: 11Last Post: 21st Dec 2014, 06:00 -
Removing audio buzz from VHS tracking
By whoisquilty in forum MacReplies: 1Last Post: 7th Dec 2014, 08:45 -
Loud buzz when outputting audio only
By joelkranz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Mar 2014, 23:12 -
AUdio ok when playing on JVC GC-PX100BE, only noise when playing on PC
By Aloha in forum Newbie / General discussionsReplies: 9Last Post: 19th Sep 2013, 12:23
