Why is there still no solution to this problem? I don't want to have to use AviSynth or VirtualDub. I am forced to save as an uncompressed AVI file to prevent this conversion.
Actually most uncompressed YUV AVI get converted to RGB as well . Only certain fourcc's get YUV treatment
eg. UYVY for 8bit422 and v210 for 10bit422 .
CC2017 actually supports lossless AVC decoding when encoded with x264 now for certain pixel types. It's decoded as YUV correctly
But even before that, "very, very, near lossless" with something like CRF1 or QP1 was supported . That's more than good enough for 99.99999% of cases. PSNR is like ~90-100db . Consider prores4444XQ is typically ~55-60db only . That's a log scale too. -
No it doesn't because I have done an export with it. Where do you see that uncompressed UYVY gets converted to RGB?
Also, I don't really see an option to export as H.264 422 lossless. I don't think the bit rate slider goes far enough, and I wouldn't know how far to drag it anyway. -
UYVY does NOT get converted to RGB. That's one of the ones I listed that worked. There are dozens of other uncompressed AVI formats that DO get converted to RGB. The majority do get converted to RGB.
But you might be able to do it with the voukoder plugin for Adobe that uses libav . I haven't tested if there are other conversions going on
But importing x264 with CRF0 or QP0 is treated as YUV in PP2017 -
Were you looking at exporting from PP only ? Or do you care how it handles re-import ?
voukoder does do lossless x264 , but only in 4:2:0 right now. On the issue tracker #9 says qp 0 doesn't work, but it does for 4:2:0 when I tested it. It's beta right now. I suggested a command line box for extra options, but the current build doesn't have one, the author said he would implement it eventually. But FFV1 (lossless) does work in 422/MKV container, but it won't re-import back into PP . You'd have to use something like avisynth or ffmpeg to use it
x264 8bit 420/422/444 lossless works when reimporting, but you can't export with PP directly (and the x264vfw plugin doesn't support 422 lossless, you have to use x264CLI or ffmpeg libx264) . You might be able to with x264pro plugin for PP but I don't use it .
(When I say "worked" I mean YUV preserved e.g. if you had super brights/darks, they would be preserved, not clipped by an RGB conversion)Last edited by poisondeathray; 30th Nov 2017 at 23:16.
Looking more closely, there are problems with the FFV1 export (the format itself works when used in other applications, but it appears some other conversions were done in the pipeline behind the scenes for the PP export. So although it's still YUV, it's not mathematically lossless when used with PP through voukoder) . Same with x264 lossless. It's treated as YUV for import (superdarks/whites don't get clipped), but there are slight differences detected. It's not mathematically lossless when used in PP (even when exporting UYVY, so it's a decoding issue) .
So if you need true mathematically lossless in/out YUV, looks like PP users are still stuck with UYVY for 8bit422 and v210 for 10bit422 -
Lagarith lossless codec / Adobe Premiere color problem
By Woncler in forum EditingReplies: 3Last Post: 7th Jun 2015, 16:58 -
Lossless (10 Bit RGB 444) and (10 Bit YUV 422) Compression Codec's
By JasonCA in forum Video ConversionReplies: 62Last Post: 25th Dec 2014, 23:40 -
is this YUV or RGB?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2014, 10:21 -
Aspect Problem: AVCHD -> Premiere -> YUV -> deinterlace -> YUV -> Encore
By fleischverpackung in forum Video ConversionReplies: 8Last Post: 21st Feb 2014, 13:15 -
optimal quality yuv to rgb conversion in premiere
By codemaster in forum EditingReplies: 3Last Post: 9th Oct 2013, 16:01
